Re: Trouble with 68 B body axles.
[Re: gtsdude]
#99673
08/04/08 04:28 PM
08/04/08 04:28 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
You migh be able to use the green bearings, as they do not require the adjuster. I am not sure if your axles have enough spline engagement though. Dr. Diff would know. You would not have a problem to get a couple of the right length axles for a reasonable price. You could narrrow your rearend housing also, or find an early housing. I have some myself, but you would still need new bearings. PM if you are interested.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: GTXWagon]
#99675
08/04/08 04:55 PM
08/04/08 04:55 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Since the OP measured the axles and verified they are the wrong length for the housing, missing buttons aren't the problem.
Going to Green bearings would eliminate the thrust problem but you'd be missing 5/16" of spline engagement on each axle; not good IMHO.
