Just wondering if anyone else ran into this b/4. My dads 68 road runner had axles in it when he bought it, but had a lot of play in them. Did not think much of it, car was not running anyway. Guy he bought car from had a 65 383 he put in it, we went thru motor, got it running, now new axle bearing were put in and the adjuster will screw all the way in and still have 1/4 inch or more play. Looking thru tech archives I found shorter B body axles used up to 1967. Sure enough we measure and they are the shorter ones. Anyone ever run into this? Is there any other fix other than axles for the 68-70 model B body? Just curious. Thanks.
