AC leak at junction #99661
08/04/08 03:19 PM
08/04/08 03:19 PM
Montana
FuryUs Offline OP
FuryUs  Offline OP
Montana
My 96 Ram has a leak near the condenser up front where the lines connect. There's a clip that holds the two pieces together, but even without that I can't pull the two pieces apart. Is there a trick to seperating them or a special tool? And then what--is there an o-ring in there?
Re: AC leak at junction [Re: FuryUs] #99662
08/04/08 04:14 PM
08/04/08 04:14 PM
Galveston,IN
jackel440 Offline
jackel440  Offline
Galveston,IN
yes there is a tool you clip over the lines and then push into the connector to release the internal clip.there should be 2 o-rings.I just took a 96 apart last nite when we pulled the motor
Re: AC leak at junction [Re: jackel440] #99663
08/04/08 04:16 PM
08/04/08 04:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Be sure the system is empty before removing that line.
Re: AC leak at junction [Re: stumpy] #99664
08/04/08 07:52 PM
08/04/08 07:52 PM
Texas, Dallas
G_T Offline
G_T  Offline
Texas, Dallas
Lubricate the new O-rings before reassembly - and evacuate the system before and after you work on it. The tool can be found at any autoparts store. There are a couple of types - also used for removing fuel lines. Here is a pic
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com 2012 Charger SRT8
