Wiped Out Center Cam Bearings WHY! #996566
05/21/11 12:31 PM
05/21/11 12:31 PM
dusterjp Offline OP
dusterjp  Offline OP
While instaling a new cam, we discovered the three center cam bearings are wiped out. Can't figure out why, the motor (340) always had good oil pressure (35-40 at idle after warm). Not sure if there is any damage in the lowe end, we will know more next week. The motor was built by a good builder in the Detroit area and had about 1000 miles on it. All advise is appreciated.
Re: Wiped Out Center Cam Bearings WHY! [Re: dusterjp] #996567
05/21/11 12:35 PM
05/21/11 12:35 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Something was not installed right. The bearing was crooked ....dirt ....
Re: Wiped Out Center Cam Bearings WHY! [Re: dOrk !] #996568
05/21/11 01:09 PM
05/21/11 01:09 PM
Hr up from KCK
451 D*O*D*G*E Offline
Hr up from KCK
Sounds like the other cam was to tight and created to much heat.
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: Wiped Out Center Cam Bearings WHY! [Re: dusterjp] #996569
05/21/11 01:17 PM
05/21/11 01:17 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Sometimes they get ugly looking, even if the original fit was nice and smooth. I wouldn't worry about it as long as the holes all still line up. It's sometimes hard to slide a new cam into block when engine is in car still w/out bumping a bearing or two with a lobe or two. But if the bearings really look bad, you know what you gotta do.
Re: Wiped Out Center Cam Bearings WHY! [Re: dusterjp] #996570
05/21/11 09:17 PM
05/21/11 09:17 PM
can you post a pic to help us figure if it's abnormal or not
