Race Fuel in a street car #996251
05/20/11 03:23 PM
05/20/11 03:23 PM
Maryland
wally426ci Offline OP
Maryland
I thought about expirementing with 100 octane race fuel in my 412 stroker. I dont race, but i figured it may be neat to mess around with a gallon added to end in a full tank.
Are there any concerns, negatives? postitives?
I am no expert, so I am not looking for responses that say "whats the point?"
I thought it may put a little more pep in my step.
$8.98 a gallon at Sunoco up the street from me and you can pump straight into the car up to $140.
Re: Race Fuel in a street car [Re: wally426ci] #996252
05/20/11 04:08 PM
05/20/11 04:08 PM
the (only) negative afaik is that it will flatten your wallet. The positive is it's the best plan for a high DCR/fast curve eng to elim deadly pinging. You'd want to add your quantity in the middle of the tank or else slosh it around thoroughly for a uniform mix. If you build a monster it needs to b fed properly. EDIT Forgot about the lead content advantage for your valves/seats but it'd take alot more than a gallon to have a positive effect on that
Re: Race Fuel in a street car [Re: wally426ci] #996253
05/20/11 04:14 PM
05/20/11 04:14 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
I did it a long time ago in a 440 '67 GTX I had. Just 1 tank, but I could really tell the difference. I also have a friend that was in the Navy back in the day, he said he used to run straight avgas in his when he came home on leave. Said it was almost like having nitrous .
Re: Race Fuel in a street car [Re: 440child] #996254
05/20/11 04:23 PM
05/20/11 04:23 PM
minnesota
Kirby Offline
Kirby  Offline
minnesota
Smells good!
Re: Race Fuel in a street car [Re: Kirby] #996255
05/20/11 04:32 PM
05/20/11 04:32 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Smells good!
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Race Fuel in a street car [Re: RoadRunner] #996256
05/20/11 05:14 PM
05/20/11 05:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
One gallon in a full tank wont do anything but waste $$$$$.I run 112 in my 440 on the street at times.It has 12.5 domes so it helps.Usually I just run 93 and keep my foot out of it.Rocky
Chrysler Firepower
Re: Race Fuel in a street car [Re: therocks] #996257
05/20/11 05:19 PM
05/20/11 05:19 PM
we missed that completely & that is if it is pinging it'll take alot more than a gallon so I'd suggest if pinging is a prob & you 're not wanting to just experiment to use however much percentage is needed as you dont want to shorten the curve and no fun keeping your foot out of it
Re: Race Fuel in a street car [Re: RapidRobert] #996258
05/20/11 05:48 PM
05/20/11 05:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
If its pinging then yes it will help with that. But if it runs fine and no ping just putting race gas in will do nothing. It will allow you to make adjustments to get more power such as advancing the timing but just putting race gas in the tank will not give it more power. You would have to make adjustments but when you go back to pump you will have to change it back. And in cold weather race gas is much harder to start the car on. Ron
Re: Race Fuel in a street car [Re: 383man] #996259
05/20/11 06:01 PM
05/20/11 06:01 PM
Maryland
Maryland
Thanks Guys, exactly the feedback I was looking for. I was curious if it was worthwhile. I have heard that a 20% mix is good but not sure on that. I guess I will just keep on pump gas since i have no pinging issues.
Re: Race Fuel in a street car [Re: wally426ci] #996260
05/20/11 06:13 PM
05/20/11 06:13 PM
God's Country - Etowah, TN.
A34 Offline
A34  Offline
What is your compression now and where is the timing set? 412 is a SB?
God Bless America, Our Troops and Their Families !
DEO VINDICE
Re: Race Fuel in a street car [Re: A34] #996261
05/20/11 08:05 PM
05/20/11 08:05 PM
Maryland
Maryland
Yep, its a stroked 360.
Honestly, i sort of gathered this motor piece by piece and am not up on the specs. Im running a 4" stroker kit, eagle rods, KB pistons, comp cam - don't have the grind memorized.
stock 68 340 cast iron intake with 750 edelbrock. Runs great, but i never degreed the cam or anything so whenever the next time i rebuild my car - I will be stripping this down and going through everything to make sure it is all good.
Re: Race Fuel in a street car [Re: wally426ci] #996262
05/20/11 08:25 PM
05/20/11 08:25 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I used to run it 50/50 in my Harley..Clean burning and really livened up the bike..
A gallon will make zero diff in your car...try 4 gallons in a 16 gallon mix..
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Race Fuel in a street car [Re: 72N96RR] #996263
05/20/11 08:39 PM
05/20/11 08:39 PM
My Moped has a 1/2 gal tank. I should go over to Ernies' & buy a quart of 110 race gas
Re: Race Fuel in a street car [Re: 72N96RR] #996264
05/20/11 10:05 PM
05/20/11 10:05 PM
A34 Offline
A34  Offline
If that doesn't help, go to a 3:1 ratio.
DEO VINDICE
Re: Race Fuel in a street car [Re: 383man] #996265
05/20/11 10:29 PM
05/20/11 10:29 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
best answer so far! and I didn't know high octane was hard to start in cold weather.
If anything, you want the lowest octane the engine will run on without pinging for maximum performance. Octane has a cooling effect in the combustion chamber, and for maximum hp I think you want the chamber as hot as possible without pinging. If I'm correct (), more octane than the engine needs could actually lower your HP.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Race Fuel in a street car [Re: GO_Fish] #996266
05/20/11 10:49 PM
05/20/11 10:49 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
TOOOOO much octane can actually slow the car down.
Re: Race Fuel in a street car [Re: dOrk !] #996267
05/22/11 07:54 AM
05/22/11 07:54 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I have a 440 that's 10.25:1. I run 50/50 mix with 100/93, works and smells great! I run 93 in the GTX with 9.7:1. The 100 I just bought was $7/gal!
Re: Race Fuel in a street car [Re: 63stabamatic] #996268
05/25/11 03:29 PM
05/25/11 03:29 PM
Brighton, MI, USA
kb73rr Offline
kb73rr  Offline
Brighton, MI, USA
The local community airport has 100/110LL av-gas. It's pure gasoline with 0% ethanol or mtbe. It runs in $6.00/gal range (here now) so 5 gallons costs like an extra $10. Bring your own can. If they ask for a tail number (N-number) you can make up any three digits or tell them it's for an ultralight (they have no N-number). Or you can do what I do, glance at your RR with a stupid grin. Take your rocket fuel home, add it to a half tank of 93, crank the timing ahead about 5-10 degrees and have fun. Disclaimer - destroys catalytic converters and O2 sensors and legal for off-road use only.
1973 Road Runner 2006 Grand Cherokee http://www.muskie-lures.com/73roadrunner/index1.htm "An entrance ramp is a terrible thing to waste"
Re: Race Fuel in a street car [Re: kb73rr] #996269
05/25/11 03:45 PM
05/25/11 03:45 PM
CA
David Lee Online content
David Lee  Online Content
CA
av gas is not pure gasoline that is a myth that is old as I can think of. IT has a much higher lead content.
The main petroleum component used in blending avgas is alkylate, which is essentially a mixture of various isooctanes, and some refineries also use some reformate. Avgas has a density of 6.02 lb/U.S. gal at 15 °C, or 0.721 kg/l, and this density is commonly used for weight and balance computation. Density increases to 6.40 lb/US gallon at -40 °C, and decreases by about 0.5% per 5 °C (9 °F) increase in temperature.[1] Avgas has an emission coefficient (or factor) of 18.355 pounds CO2 per U.S. gallon (2.1994 kg/l)[2][3] or about 3.05 units of weight CO2 produced per unit weight of fuel used. Avgas has a lower and more uniform vapor pressure than automotive gasoline, which keeps it in the liquid state at high-altitude, preventing vapor lock.
Buy real race like c112. I run in it my stocker and it has a real distictive smell to it. But beware you can get heavilly fined running race gas in your car. It has lead in it and the federal road taxes have not been paid on it.
Ah...so many pedestrians, so little time...
Re: Race Fuel in a street car [Re: David Lee] #996270
05/25/11 05:23 PM
05/25/11 05:23 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Higher octane gas actually has a lower power output if measuring them side by side. High octane helps in pre-ignition with high CR motors and runs cooler, great in a radial motor, not so great in a V. I think RR/Merlin motors on takeoff had water injection and 50 PSI of manifold boost and liked about 130 octane. Did you know CNG has 130 octane? Gets you thinking about a 14.5:1 street motor on the fart that you can drive in the CA carpool lane!
