Flattening clear coat???? #994797
05/18/11 07:06 AM
05/18/11 07:06 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
Anyone here paint or have had some one paint a satin finish on there car? looking for a additive to mix in clear.
Thanks, Jim
Re: Flattening clear coat???? [Re: jb15] #994798
05/18/11 08:15 AM
05/18/11 08:15 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
If you are buying your paint from an auto paint store, they will be able to add a flattening agent when they mix your colors. Or they should be able to add it to clear.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Flattening clear coat???? [Re: rattler] #994799
05/18/11 08:18 AM
05/18/11 08:18 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You can buy satin clear. Great for hood black outs.
Re: Flattening clear coat???? [Re: jb15] #994800
05/18/11 08:20 AM
05/18/11 08:20 AM
Springfield Oregon
badblubeee Offline
super gas
badblubeee  Offline
super gas
Springfield Oregon
Yeah I used flattening agent in the clear on my convert-one quart to a gallon of clear and it really didn't do much to dull it.Maybe a 1 to 1 ratio would work. I bought the stuff at the paint supplyer.
Re: Flattening clear coat???? [Re: badblubeee] #994801
05/18/11 08:48 AM
05/18/11 08:48 AM
canada,NB
jb15 Offline OP
jb15  Offline OP
canada,NB
I have a gallon of clear I want to use,looking for a brand or product # that some of you may have tryed.
Thanks, Jim.
Re: Flattening clear coat???? [Re: badblubeee] #994802
05/18/11 08:52 AM
05/18/11 08:52 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
the newer high solids clear coats don't flatten out that good by adding regular flattening agent.
most paint manufacturers make pre flattened clear coat just for that reason.
i know PPG has 2 different flattened clear coats.
perception is 90% of reality
Re: Flattening clear coat???? [Re: Mr T2U] #994803
05/18/11 10:16 AM
05/18/11 10:16 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
I have also tried to use flatting agent in the regular clear .
IT did not work that good you would have to use quite a bit of the stuff to make it flat . i use it 25% on the plastic satin Finnish parts on some of the foreign cars and it works OK for that .
1969 Dodge Charger 1969 Dodge Superbee
