Re: Flattening clear coat????
[Re: badblubeee]
#994802
05/18/11 08:52 AM
05/18/11 08:52 AM
Posts: 4,913 new berlin wisconsin
Mr T2U
the newer high solids clear coats don't flatten out that good by adding regular flattening agent. most paint manufacturers make pre flattened clear coat just for that reason. i know PPG has 2 different flattened clear coats.
perception is 90% of reality
[Re: Mr T2U]
#994803
05/18/11 10:16 AM
05/18/11 10:16 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
I have also tried to use flatting agent in the regular clear . IT did not work that good you would have to use quite a bit of the stuff to make it flat . i use it 25% on the plastic satin Finnish parts on some of the foreign cars and it works OK for that .
1969 Dodge Charger
1969 Dodge Superbee
