Crank Trigger #994557
05/17/11 10:40 PM
05/17/11 10:40 PM
SD800 Offline OP
SD800  Offline OP
Guys,
Just installed a crank trigger on the 572 in my challenger.
We set initial timing at 34 degrees advanced and fired it up.it idles at 1100 rpm at 34 degrees but when you whack the throttle the timing will retard by 10 degrees.
I know there is some loss of timing with the timing chain and gears between the distributor gear but I never realized it wAs this much.
Is this normal with a crank trigger and is there a way to compensate for this?
You'll have plenty of time to sleep when your dead, let's go
Re: Crank Trigger [Re: SD800] #994558
05/17/11 10:43 PM
05/17/11 10:43 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have a gear drive on mine, but the timing is rock steady. Is your distrib locked?
Brian Dunnigan
Re: Crank Trigger [Re: '72CudaRacer] #994559
05/17/11 10:53 PM
05/17/11 10:53 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The dizzy needs welded solid. Make sure to phase the rotor to the cap at the time the crank trigger is making contact.
Re: Crank Trigger [Re: '72CudaRacer] #994560
05/17/11 10:53 PM
05/17/11 10:53 PM
SD800 Offline OP
SD800  Offline OP
Yes the distributor is locked out
Re: Crank Trigger [Re: SD800] #994561
05/17/11 10:59 PM
05/17/11 10:59 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not sure what that is, should be rock solid, no movement at all. One thing to try is the polarity could be wrong on the pickup. That will usually cause it it be off because of a leading edge/trailing edge thing but it still should not move
Re: Crank Trigger [Re: SD800] #994562
05/17/11 10:59 PM
05/17/11 10:59 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
shouldn't move unless you have some kind of retard set up on a timming computer. the distributor not locked won't change the timming just the rotor phasing.
Re: Crank Trigger [Re: FastmOp] #994563
05/17/11 11:00 PM
05/17/11 11:00 PM
SD800 Offline OP
SD800  Offline OP
we did phase the distributor the best we could,would turning the distributor to better phase it reduce or fix this?
Re: Crank Trigger [Re: SD800] #994564
05/17/11 11:01 PM
05/17/11 11:01 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What is the rest of the ignition system?
Re: Crank Trigger [Re: SD800] #994565
05/17/11 11:08 PM
05/17/11 11:08 PM
SD800 Offline OP
SD800  Offline OP
Does it matter which way the wheel is installed,in order for the wheel to center on the balancer we had to install the wheel with the rotation arrow against the balancer
Re: Crank Trigger [Re: Al_Alguire] #994566
05/17/11 11:14 PM
05/17/11 11:14 PM
SD800 Offline OP
SD800  Offline OP
MSD 6AL box and MSD distributor moroso crank trigger
Re: Crank Trigger [Re: SD800] #994567
05/17/11 11:25 PM
05/17/11 11:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
What's the gap?
Good call on timing not moving with dizzy unlocked. I was tired
I'm a little confused on this one now with the parts u listed. You should be up and running. Try to swap the wheel. It's got an arrow for a reason I guess.
Re: Crank Trigger [Re: FastmOp] #994568
05/17/11 11:36 PM
05/17/11 11:36 PM
SD800 Offline OP
SD800  Offline OP
Gap is set at .050
Re: Crank Trigger [Re: SD800] #994569
05/17/11 11:39 PM
05/17/11 11:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Does the timing stabilize at a higher RPM?
Re: Crank Trigger [Re: Al_Alguire] #994570
05/17/11 11:58 PM
05/17/11 11:58 PM
SD800 Offline OP
SD800  Offline OP
Al,
I did not bring it to a high rpm to see what it does,I would increase the rpm to about 2000 rmp and the timing would smooth out at 34 degrees but if you whacked the throttle, maybe 4000 rmp it will retard by 10 degrees on the hit.
Re: Crank Trigger [Re: SD800] #994571
05/18/11 02:18 AM
05/18/11 02:18 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
What brand timing light??
Borrow another light, and hook it to a battery not running the car, and confirm reading.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Crank Trigger [Re: SD800] #994572
05/18/11 02:20 AM
05/18/11 02:20 AM
Down under
slantman Offline
slantman  Offline
Down under
I'm pretty sure the rotation arrow has to be facing out, away from the balancer. Otherwise the polarity of the flying magnets is the wrong way round. The engine will still run, but not make power as it revs up.
Re: Crank Trigger [Re: SD800] #994573
05/18/11 02:22 AM
05/18/11 02:22 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What Billy said is an excellent point. Before panic sets in might be a good idea to "get a second opinion".
Cant think of any logical reason to see what you are seeing. is the Moroso pickup wire shielded? Is the pickup wiring running near anything else electrical, particularly the water pump? Sometimes you can get some unwanted RF that will cause all sorts of crazy things to happen.
I missed the part about the arrow. Would definitely want it installed correctly with rotation. I assume they put them that way for a reason?
Re: Crank Trigger [Re: Al_Alguire] #994574
05/18/11 05:14 AM
05/18/11 05:14 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Arrow MUST face out, that's the most likely cause of your error.
http://www.youtube.com/watch?v=TCHEHPESf60
Fast forward to 6:00 mark and it explains the issue. S/F....Ken M
Re: Crank Trigger [Re: EchoSixMike] #994575
05/18/11 09:40 AM
05/18/11 09:40 AM
SD800 Offline OP
SD800  Offline OP
Sounds like that may be my issue.
Thanks for the help guys
Re: Crank Trigger [Re: SD800] #994576
05/18/11 03:28 PM
05/18/11 03:28 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
While your at it check all 4 magnets. All four should either repel or attract. If not the offending magnet(s) can affect that cylinders pick-up.
Doug
