440 build-up - How does this combo sound? #993501
05/16/11 11:04 AM
05/16/11 11:04 AM
Central NJ
rjh233 Offline OP
rjh233  Offline OP
Central NJ
Hi everyone,
I'm looking to rebuild the 440 in my 65 Coronet for street/strip duty. I want to be able to run on pump gas to retain streetability. I live in NJ so I can get 92/93 octane. I am planning on a 4.15 stroker crank and rods from 440 source, with .030 over SRP forged pistons (p/n 231521 - 4032 alloy), Edelbrock Performer Alumimum heads (p/n 60929), Comp Cams Comp Kit CCA-K21-233-4 (290/298 .540/.558 - solid flat tappet) with Comp 1621 roller rockers (1.5 ratio), Edelbrock Performer 440 dual plane manifold (2191), Carter thermoquad, a 2800 stall converter, 3.91 gears (I also have a set of 3.55s and 3.23s to try out too if necessary) and 26 inch tall Mickey Thompson ET Drag radials. The cars has Mopar Performance Super Stock springs too.
With those edelbrock heads (84cc), a .039 gasket, knocking .010 off the deck of the block (guesstimate), on paper, the compression ratio works out to 10.75:1 and the pistons are .015 down in the hole.
Any ideas on what to expect horsepower-wise with this setup and what times I will run in the 1/4-mile? Are the Edelbrock Victor heads a good setup up, or are Victors too much for the street?
Suggestions welcome.
Thanks,
Rob
Re: 440 build-up - How does this combo sound? [Re: rjh233] #993502
05/16/11 11:20 AM
05/16/11 11:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
poo poo intake. Get the RPM. With the thermo-q you'll need an apdapter. If you have a good WORKING thermo use if if not I'd just drop a few $$ on a 850DP. Also you'll need more stall w/ that cam, probably 3200 or so. And it will be a dog w/ 3.23, very Avg w/ 3.55's 3.91's will work. Headers? (I hope) as far as tack times, after you tune it I'd guess low 12's high 11's. Those are short tires so that will help get that thing moving.
Coming soon!!!!
Re: 440 build-up - How does this combo sound? [Re: rjh233] #993503
05/16/11 09:18 PM
05/16/11 09:18 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I agree with Mr Yuck here except for the "it will be a dog with 3.23s" part. With the parts listed and a better intake and converter your car should easily go high 11s no matter what gear is in it.My Satellite has gone lots of mid 12s (12.35 best) with an 8.5 440, barely pocket ported 906s with stock valves, Comp 292 hyd , old Torker, 750 DP. 10 inch converter, about 3800 flash. 3.23 gears and 28x9 et drags. Cheapo motor with not much power would only trap 106-107. Would pull a 1.69 60ft tho with those crappy gears and tall tires. Converter was doing all the work. I drive it on the highway quite a bit and 3.91s and a 26 inch tire would get old in a hurry for me.
Re: 440 build-up - How does this combo sound? [Re: forphorty] #993504
05/16/11 09:33 PM
05/16/11 09:33 PM
Central NC
gch Offline
gch  Offline
Central NC
Run the street dominator intake if you want to run the TQ.Maybe a better intake for your setup no matter the carb.
TQ will need major tuning for the stroker.Be prepared to dial it in.
Gears won't matter much.3.55's for mostly street and 3.91's for more track.
Converter won't matter much with the torque of the stroker.Do get a quality converter with minimal slippage.
Re: 440 build-up - How does this combo sound? [Re: gch] #993505
05/16/11 10:17 PM
05/16/11 10:17 PM
okla.
sam64 Offline
sam64  Offline
okla.
i vote for the performer rpm,unless you are planning spinning that thing 7,000.it picked my car up a bunch over a single plane,i shift at 6300.3400lbs 11.30s.leaving@2200rpm.
Re: 440 build-up - How does this combo sound? [Re: sam64] #993506
05/16/11 10:41 PM
05/16/11 10:41 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
i vote for the performer rpm,unless you are planning spinning that thing 7,000.it picked my car up a bunch over a single plane,i shift at 6300.3400lbs [Email]11.30s.leaving@2200rpm.[/Email]
I believe you went from a 4150 Team G to the RPM, correct? The 4150 Team Gs usually have major issues.....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 build-up - How does this combo sound? [Re: Von] #993507
05/16/11 10:43 PM
05/16/11 10:43 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Id go with a single plane...with 500 cubes I see no reason for a dual plane. Unless it is the Indy intake with some port work.
SD or M1 should work well. More converter, maybe a Vic.
Id go more cam, converter and a Vic, but apparently (on this board anyway)Im pretty liberal....
Re: 440 build-up - How does this combo sound? [Re: forphorty] #993508
05/16/11 10:50 PM
05/16/11 10:50 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Well Tim, you beat me to the 3.23 comment.
I agree that the ops combo should go 11s...with ease.
I have 50 less cubes, more cam, more weight, less heads, bigger headers, etc and it ran fine on the street with 3.23s......No where near a "dog".
Ya, at the track the 3.23s would cost me..But the butt dyno doesnt say more than 2 tenths..FWIW.
Re: 440 build-up - How does this combo sound? [Re: Von] #993509
05/16/11 10:52 PM
05/16/11 10:52 PM
Sounds like the converter is key. That's convincing me to spend the money for a good one for my specs
Re: 440 build-up - How does this combo sound? [Re: RapidRobert] #993510
05/16/11 10:58 PM
05/16/11 10:58 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote Sounds like the converter is key. That's convincing me to spend the money for a good one for my specs
Right you are!!!
But, in Tims case (forphorty above) I believe his ETS were with.... a GER converter.
Im sure he will respond, but I believe he has a dyamic now and the car doesnt run any quicker. For sure not the general rule of thumb...But the GER worked.
Re: 440 build-up - How does this combo sound? [Re: Von] #993511
05/16/11 11:03 PM
05/16/11 11:03 PM
Actually I was asking as I am converter ignorant but you (& others) are convincing me that it is a critical piece
Re: 440 build-up - How does this combo sound? [Re: RapidRobert] #993512
05/16/11 11:08 PM
05/16/11 11:08 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
The best converter Ive had/have is a TA 8 inch. Flashes 5k and drives VERY nice on the street. The converter started life as a Munsinger and TA went through it last. So, not sure if all TA "tight" 8s are as good.
For the money, PTC gets my vote. 4 bills and change you get a really good converter.
Re: 440 build-up - How does this combo sound? [Re: RapidRobert] #993513
05/16/11 11:12 PM
05/16/11 11:12 PM
okla.
sam64 Offline
sam64  Offline
okla.
yes the converter is very important,but you have to make all the other choices of your engine before you call anyone to spec a converter to your combo.
Re: 440 build-up - How does this combo sound? [Re: Von] #993514
05/16/11 11:20 PM
05/16/11 11:20 PM
okla.
sam64 Offline
sam64  Offline
okla.
m1 is no better than a team g i can guarantee that,now back to rpms its going to be ran at most of the time,that will make the difference.if i'm gona spend someone elses money its gonna have somethin pushin air.
Re: 440 build-up - How does this combo sound? [Re: sam64] #993515
05/17/11 12:20 AM
05/17/11 12:20 AM
Will do
Re: 440 build-up - How does this combo sound? [Re: Von] #993516
05/17/11 12:20 AM
05/17/11 12:20 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Right you are!!!
Yep, GER. Haven't run it with the Dynamic. Doesn't feel any faster with it, but also doesn't crack flex plates like the GER did on a regular basis. Poor car is falling apart. I need to plug the leaks and rebuild the front suspension before it runs down the track again. And the front floor pans are beginning to look like Fred Flintstones.
Re: 440 build-up - How does this combo sound? [Re: rjh233] #993517
05/17/11 12:30 AM
05/17/11 12:30 AM
Redding,CA USA
440charger500 Offline
Redding,CA USA
Everything sounds good to me but the converter and 26" M/T slicks. I've been there done that and I can tell you a 27" or 28" tire will hook better and go with the 3.91 gears. I bought a dynamics 10" 3500 converter and I picked up three tenths from another brand 2800 stall converter. If it was me I would run the 3.91 with 28" tire and a 3000+ converter. You will be mid 12'S or better and will drive on the street no prob.
Re: 440 build-up - How does this combo sound? [Re: sam64] #993518
05/17/11 12:44 AM
05/17/11 12:44 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
[quote m1 is no better than a team g i can guarantee that, [/quote
4500 flange Team G probably is better.. 4150 flange most likely not...
I discussed this very subject with Dwayne a couple of weeks ago. I saw how how much improvment you got going to a RPM and it had me thinking. But, after talking with Dwayne I have a better understanding of why you might have picked up so much with the intake swap...
Re: 440 build-up - How does this combo sound? [Re: gch] #993519
05/17/11 12:56 AM
05/17/11 12:56 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
with both forforty and gch, carb/intake and converter. The SD would be the WISER choice with the TQ, 850 DP would like the Air Gap. with the "long" 3.23's, that 8" converter works the tranny. Personally, I'd cut back an inch (that's my own op).
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 440 build-up - How does this combo sound? [Re: forphorty] #993520
05/17/11 01:11 AM
05/17/11 01:11 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Not a bad combo at all but I would make a few changes. More converter , a better intake and I myself would use a Holley DP carb for your setup. Its very close to my 440 other then yours will be stroked. I have the MP .557 cam that looks close to your cam by the specs you have. I run the Holley SD intake which should work nice on your combo. I have seen some strokers running the Performer RPM intake and they seem to work good on mild strokers. The RPM surprised me as how good it still pulls up at 6500 as my son uses one on his 400 in his Dart. Its a nice street/strip intake also. I use a Dynamic 9.5 converter that flashes about 4200 but drives like a normal converter. I really like that converter in my street/strip cars. I would say with a good intake (SD or RPM) and a nice converter with about 3800 flash and an 850 DP at least will really bring it alive. 11's should be easy for you then.
I am pulling my 440 out this week to put my new 493 stroker in my 63 and my old 440 will be going in my buddies black 65 Coronet 500. He does not want to put a roll bar in it so he does not want to go faster then 11.50's. My car went 11.49 with it so his 65 should run mid 11's and your's should run easy 11's and even low 11's if you really get aggressive with your combo. Got any pics of your 65 ? Good luck , Ron
