Frame connectors advice #993483
05/16/11 10:46 AM
05/16/11 10:46 AM
Out in Left Field, NY
bobs66440 Offline OP
I was wondering what the max HP/torque engine would be recommended for a stock B-body before frame connectors would be required. I'm looking at rebuilding my engine (440-4 speed) this winter and would like around 450hp, but don't want to go through the work of frame connectors. I do not plan on driving it hard but occasional spirited driving.
Thanks, Bob
Re: Frame connectors advice [Re: bobs66440] #993484
05/16/11 11:07 AM
05/16/11 11:07 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I don't think it's HP/TQ thing. Connectors will "tighten" the car up no matter what engine combo you have. Cheapest and easiest upgrade I did on my car. It will ride and handle much better even without cutting into the floors. Much less work than your planned engine build(much cheaper also)
Re: Frame connectors advice [Re: Dcuda69] #993485
05/16/11 12:24 PM
05/16/11 12:24 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
X2.
They will help remove squeaks and rattles and make everything else in the suspension work more efficiently. IMO, they are a benefit regardlesss of power. Even the simple bolt in style 1x2 types will help out immensly.
Re: Frame connectors advice [Re: bobs66440] #993486
05/16/11 08:43 PM
05/16/11 08:43 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I'm with those guys
Re: Frame connectors advice [Re: forphorty] #993487
05/16/11 10:17 PM
05/16/11 10:17 PM
Me too & the ones that fit/weld to/thru the floor pan work even better
Re: Frame connectors advice [Re: RapidRobert] #993488
05/16/11 10:47 PM
05/16/11 10:47 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Do your homework as some weld on frame connectors fit better than others , But they make a great improvement in stiffness
