Need a small block water pump recommendation #992956
05/15/11 03:18 PM
05/15/11 03:18 PM
Space Station #5
471Magnum Offline OP
Space Station #5
I'm in the process of assembling my small block stroker. Had originally planned to just re-use the water pump off my stock 340, but after seeing how crusty it is, I'm going to spring for a new one.
Not looking for anything super high performance, but I want to make sure I get one that will move enough water to keep things cool with the extra power that will be on tap.
Rock Auto lists about 10 different pumps; some with six vanes, some with eight, some with A/C, and some without. Other than impeller design, are there any differences?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Need a small block water pump recommendation [Re: 471Magnum] #992957
05/16/11 08:23 AM
05/16/11 08:23 AM
Space Station #5
Space Station #5
Come on small block guys... share the knowledge. Need to place my order today.
Re: Need a small block water pump recommendation [Re: 471Magnum] #992958
05/16/11 09:20 AM
05/16/11 09:20 AM
Actually most any wp is fine even rebuilt ones have a good track record. The MP one is good but pricey. Weld on an anticav plate. Get an 8 blade one and support the front shaft in front of the cross & press the vanes in the rear more forward till you have ~.040" clearance to the body and can mill the tim cover so you end up w .040" clearance from the anti cav plate to the flat (factor in your gasket thickness & adj bolt/washer length). Makes the pump FAR more efficient. Inside the tim cover 2 main water passages is a slight casting mold about halfway in on each one that can b removed w a whizzer in 15 seconds and use the smallest WP pulley you can fit. Have more but is the block bare or almost together
Re: Need a small block water pump recommendation [Re: 471Magnum] #992959
05/16/11 10:03 AM
05/16/11 10:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use a FlowKooler pump on my 550 hp 408 and have no cooling issues.
Re: Need a small block water pump recommendation [Re: justinp61] #992960
05/16/11 10:59 AM
05/16/11 10:59 AM
Löffingen, Germany
The_Mean_Machine Offline
Löffingen, Germany
same here..., no further mods equired.
Re: Need a small block water pump recommendation [Re: justinp61] #992961
05/16/11 11:05 AM
05/16/11 11:05 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I used the one spec'd for cop car apps. I think its a max cooling package part. the main visual diff is the shaft dia. 5/8" vs 1/2". It always kept my 340 cool , stop and go woodward cruise or on the highway @ 70 , 80 or more.
Part #4728533. don't know if it's still ava.
I'm using a Milidon hv pump on my 416 , it does ok but the temp seems to creep at highway speeds.
Re: Need a small block water pump recommendation [Re: The_Mean_Machine] #992962
05/16/11 12:44 PM
05/16/11 12:44 PM
Space Station #5
Space Station #5
I had a brand new FlowKooler puke all over my freshly detailed big block.
Never again.
-Jim
Re: Need a small block water pump recommendation [Re: 471Magnum] #992963
05/16/11 01:11 PM
05/16/11 01:11 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Get a cheap a/c water pump and put the cavatation plate on it. Way cheaper and works just as good as the high dollar pumps. Been there, done that-bought the t shirt.
Re: Need a small block water pump recommendation [Re: DusterKrazy] #992964
05/16/11 01:22 PM
05/16/11 01:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....although I'd buy a premium A/C rebuilt pump, and add the impeller plate,....I,ve had this same set-up on my Challenger T/A for about 20 years now
Re: Need a small block water pump recommendation [Re: DAYCLONA] #992965
05/16/11 01:37 PM
05/16/11 01:37 PM
Space Station #5
Space Station #5
Just ordered a Gates pump.
Re: Need a small block water pump recommendation [Re: 471Magnum] #992966
05/17/11 02:55 PM
05/17/11 02:55 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..standard water pump is fine.
..get your pulley size correct
..8 vane ac or cop units use a small pulley
..6 vane units use a large pulley
i hope i got that right,but you get the idea.
Re: Need a small block water pump recommendation [Re: can.al] #992967
05/17/11 10:21 PM
05/17/11 10:21 PM
Andrewh Offline
Andrewh  Offline
you got it backwards.
6 vane a/c small pulley.
8 vane without a/c larger pulley.
Re: Need a small block water pump recommendation [Re: Andrewh] #992968
05/17/11 10:29 PM
05/17/11 10:29 PM
OE Correct and 8 vane/small pulley w anti cav plate/adjusted distances on both sides of the vanes gives the best of both worlds
Re: Need a small block water pump recommendation [Re: RapidRobert] #992969
05/17/11 11:40 PM
05/17/11 11:40 PM
East Brunswick, NJ
finadk Offline
finadk  Offline
East Brunswick, NJ
I went with a Flow Kooler Part # 1700. As advertised it should address any problems with my underdrive March Pulleys. Got it from Summit. Im still assemblying the engine so cant say for sure but I have high hopes.
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
Re: Need a small block water pump recommendation [Re: finadk] #992970
05/18/11 12:01 AM
05/18/11 12:01 AM
Diplomat cop units have a bigger main 5/8 shaft (turned down on the end for the pulley) and have ribs instead of the holes that a standard pump has.
