Need a small block water pump recommendation
#992956
05/15/11 03:18 PM
05/15/11 03:18 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I'm in the process of assembling my small block stroker. Had originally planned to just re-use the water pump off my stock 340, but after seeing how crusty it is, I'm going to spring for a new one.
Not looking for anything super high performance, but I want to make sure I get one that will move enough water to keep things cool with the extra power that will be on tap.
Rock Auto lists about 10 different pumps; some with six vanes, some with eight, some with A/C, and some without. Other than impeller design, are there any differences?
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Need a small block water pump recommendation
[Re: 471Magnum]
#992958
05/16/11 09:20 AM
05/16/11 09:20 AM
RapidRobert
Actually most any wp is fine even rebuilt ones have a good track record. The MP one is good but pricey. Weld on an anticav plate. Get an 8 blade one and support the front shaft in front of the cross & press the vanes in the rear more forward till you have ~.040" clearance to the body and can mill the tim cover so you end up w .040" clearance from the anti cav plate to the flat (factor in your gasket thickness & adj bolt/washer length). Makes the pump FAR more efficient. Inside the tim cover 2 main water passages is a slight casting mold about halfway in on each one that can b removed w a whizzer in 15 seconds and use the smallest WP pulley you can fit. Have more but is the block bare or almost together
[Re: The_Mean_Machine]
#992962
05/16/11 12:44 PM
05/16/11 12:44 PM
471Magnum
Space Station #5
I had a brand new FlowKooler puke all over my freshly detailed big block.
Never again.
-Jim
[Re: DusterKrazy]
#992964
05/16/11 01:22 PM
05/16/11 01:22 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Get a cheap a/c water pump and put the cavatation plate on it. Way cheaper and works just as good as the high dollar pumps. Been there, done that-bought the t shirt.
.....although I'd buy a premium A/C rebuilt pump, and add the impeller plate,....I,ve had this same set-up on my Challenger T/A for about 20 years now
[Re: can.al]
#992967
05/17/11 10:21 PM
05/17/11 10:21 PM
Andrewh
..standard water pump is fine. ..get your pulley size correct ..8 vane ac or cop units use a small pulley ..6 vane units use a large pulley i hope i got that right,but you get the idea.
you got it backwards.
6 vane a/c small pulley.
8 vane without a/c larger pulley.
[Re: RapidRobert]
#992969
05/17/11 11:40 PM
05/17/11 11:40 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I went with a Flow Kooler Part # 1700. As advertised it should address any problems with my underdrive March Pulleys. Got it from Summit. Im still assemblying the engine so cant say for sure but I have high hopes.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#992970
05/18/11 12:01 AM
05/18/11 12:01 AM
Diplomat cop units have a bigger main 5/8 shaft (turned down on the end for the pulley) and have ribs instead of the holes that a standard pump has.
