Organsol on inside of AAR doors #992487
05/14/11 11:16 PM
05/14/11 11:16 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
I have a pair of doors from an AAR that was parted out in the early 80s.The panel under the poor panel has been masked and painted organsol.The car was Plum Crazy.It appears to be factory.Anybody ever seen this?
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992488
05/14/11 11:34 PM
05/14/11 11:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Got a photo?
If the mylar door sticker is still on it I would love to see a photo of it as well.
Re: Organsol on inside of AAR doors [Re: Alaskan_TA] #992489
05/15/11 10:21 PM
05/15/11 10:21 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
It was done with the door panel and gasket off the door. The paint line under the gasket doesn’t line up with the gasket line. The doors were painted gloss black on the outside and in the jam but no gloss under the gasket. Could this be to hide the purple when the door was open? If so what other colors did they do this to?
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992490
05/15/11 10:22 PM
05/15/11 10:22 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
with gasket
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992491
05/15/11 10:23 PM
05/15/11 10:23 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
The whole door
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992492
05/15/11 10:24 PM
05/15/11 10:24 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
One more were the latch handle bolts on
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992493
05/15/11 10:29 PM
05/15/11 10:29 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Maybe someone sprayed cheap undercoater in a can on it after they bought it, because they didn't like seeing the purple when the door was open?
Will the black stuff melt when you rub it with thinner?
Re: Organsol on inside of AAR doors [Re: jbc426] #992494
05/15/11 10:44 PM
05/15/11 10:44 PM
ontario calif
N
ns1aar Offline OP
ns1aar  Offline OP
N
ontario calif
Could be but there isn't any on the gasket although they might have renmoved it.Lacquer thinner took it off.Wasn't organsol lacquer based?
NS1AAR
Re: Organsol on inside of AAR doors [Re: ns1aar] #992495
05/15/11 10:55 PM
05/15/11 10:55 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That is too rough to be Organisol, it looks more like an aerosol based undercoating to me?
Re: Organsol on inside of AAR doors [Re: Alaskan_TA] #992496
05/16/11 06:27 AM
05/16/11 06:27 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
I agree. It looks like autoparts store spray on undercoating.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: Organsol on inside of AAR doors [Re: MMC Detroit] #992497
05/17/11 12:25 AM
05/17/11 12:25 AM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Organsol on inside of AAR doors [Re: Troy] #992498
07/08/11 09:54 PM
07/08/11 09:54 PM
Lancaster Pa
Transamcuda Offline
Transamcuda  Offline
Lancaster Pa
Home of the AAR Registry
www.transamcuda.com
Re: Organsol on inside of AAR doors [Re: Transamcuda] #992499
07/08/11 11:15 PM
07/08/11 11:15 PM
north carolina usa
beeson44 Offline
beeson44  Offline
north carolina usa
Zbart I think thats the name I run a resto shop in NC and had a 1973 charger to restore and it had zbart everywhere in the jambs, under hood.Thats my 2cents
Re: Organsol on inside of AAR doors [Re: ns1aar] #992500
07/09/11 05:56 PM
07/09/11 05:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looks like what was a common practice back in the day, (70'-80"s)...cheap repaint, but in another color, so the jams were usually spraybombed, or brushed in some form of flat black, some shops would even do that to blackwall tires that they were too lazy to cover up from the overspray,....they'd have a kid brush on some thinned roofing tar,...I kid you not!, seen it happen
Re: Organsol on inside of AAR doors [Re: beeson44] #992501
07/09/11 06:10 PM
07/09/11 06:10 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Exactly..
Re: Organsol on inside of AAR doors [Re: 1_WILD_RT] #992502
07/09/11 10:02 PM
07/09/11 10:02 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Exactly..
My 70 runner was done this way. It was a pain welded in all the holes they drilled to spray in the rockers and so on.
Re: Organsol on inside of AAR doors [Re: Silver70] #992503
07/13/11 12:20 AM
07/13/11 12:20 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Update, the door is here now & it is a newer type of undercoating.
