Organsol on inside of AAR doors
#992487
05/14/11 11:16 PM
05/14/11 11:16 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I have a pair of doors from an AAR that was parted out in the early 80s.The panel under the poor panel has been masked and painted organsol.The car was Plum Crazy.It appears to be factory.Anybody ever seen this?
NS1AAR
Re: Organsol on inside of AAR doors
[Re: Alaskan_TA]
#992489
05/15/11 10:21 PM
05/15/11 10:21 PM
ns1aar
ontario calif
It was done with the door panel and gasket off the door. The paint line under the gasket doesn’t line up with the gasket line. The doors were painted gloss black on the outside and in the jam but no gloss under the gasket. Could this be to hide the purple when the door was open? If so what other colors did they do this to?
NS1AAR
[Re: ns1aar]
#992492
05/15/11 10:24 PM
05/15/11 10:24 PM
ns1aar
ontario calif
One more were the latch handle bolts on
NS1AAR
[Re: ns1aar]
#992493
05/15/11 10:29 PM
05/15/11 10:29 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Maybe someone sprayed cheap undercoater in a can on it after they bought it, because they didn't like seeing the purple when the door was open?
Will the black stuff melt when you rub it with thinner?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#992494
05/15/11 10:44 PM
05/15/11 10:44 PM
ns1aar
ontario calif
Could be but there isn't any on the gasket although they might have renmoved it.Lacquer thinner took it off.Wasn't organsol lacquer based?
NS1AAR
[Re: Alaskan_TA]
#992496
05/16/11 06:27 AM
05/16/11 06:27 AM
Posts: 974 www.mmcdetroit.com
MMC Detroit
www.mmcdetroit.com
I agree. It looks like autoparts store spray on undercoating.
MMC/ ICCA Detroit.
The Motor City or where ever there is Mopars
[Re: ns1aar]
#992500
07/09/11 05:56 PM
07/09/11 05:56 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Looks like what was a common practice back in the day, (70'-80"s)...cheap repaint, but in another color, so the jams were usually spraybombed, or brushed in some form of flat black, some shops would even do that to blackwall tires that they were too lazy to cover up from the overspray,....they'd have a kid brush on some thinned roofing tar,...I kid you not!, seen it happen
[Re: 1_WILD_RT]
#992502
07/09/11 10:02 PM
07/09/11 10:02 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Zbart I think thats the name I run a resto shop in NC and had a 1973 charger to restore and it had zbart everywhere in the jambs, under hood.Thats my 2cents
Exactly..
My 70 runner was done this way. It was a pain welded in all the holes they drilled to spray in the rockers and so on.
