Need help w/97 Ram 1500 5.9L issue...please. #991994
05/14/11 12:19 AM
05/14/11 12:19 AM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
Ok, my brothers truck...1997 Ram 1500 5.9L.
Ran perfect but had a leaky head gasket, when putting it back together installed Comp cam (one cam before having to change computer), new lifters, new injectors, new TPS, new cam sensor, new crank censor, valves ground, a very meticulous craftsman. Now, it starts, runs, and idles perfect, back it up and pull it forward runs perfect, take it out on the street and drive to the stop sign and it dies, starts right up, drive it to the next stop and it dies, if he feathers the peddle it will keep running, drives it to work and gets 16mpg, if he slows to a stop at any time and it dies. When it starts to die as he is coming to a stop the rpm will go smoothly past the idle range right down to zero each time, it doesn't just die. He swapped computers with another 97 and does the same thing. He lives in Iowa and I live in Missouri, so this is a long distance diagnosis challenge.
We need help, please ask questions and I will try to answer...
Russ:)
BigBlock 74 Swinger
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: bb74swngr] #991995
05/14/11 12:32 AM
05/14/11 12:32 AM
Andrewh Offline
Andrewh  Offline
so 2 possible answers. the stock answer is IAC is bad, dirty or the hole is gummed up.
I would start there.
SEcond possible answer is, as I recall, there is some "calibration" to do when replacing the TPS.
You have to do something odd so the computer will recognize the new tps. I don't know for sure, I just remember something funny like that.
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: Andrewh] #991996
05/14/11 12:36 AM
05/14/11 12:36 AM
Missouri
mopar addict
mopar addict
Missouri
Help me out Andrehw, what is the IAC? I'm not very good on this new stuff:)
BigBlock 74 Swinger
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: bb74swngr] #991997
05/14/11 12:53 AM
05/14/11 12:53 AM
Missouri
mopar addict
mopar addict
Missouri
Headed to bed everyone...will check in tomorrow.
Russ:)
BigBlock 74 Swinger
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: bb74swngr] #991998
05/14/11 12:08 PM
05/14/11 12:08 PM
Andrewh Offline
Andrewh  Offline
idle air control valve.
it is on the throttle body.
on the back I think. bolted on, so it can be removed and cleaned. the hole it taps in to should be cleaned as well.
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: Andrewh] #991999
05/14/11 12:12 PM
05/14/11 12:12 PM
Missouri
mopar addict
mopar addict
Missouri
Good morning Andrewh! Sorry, I didn't know that one:) Yes, he tried cleaning the IAC and that didn't help, so he relaced it, and that didn't help:(
BigBlock 74 Swinger
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: bb74swngr] #992000
05/14/11 03:47 PM
05/14/11 03:47 PM
Andrewh Offline
Andrewh  Offline
iac could be bad. the motor itself.
but check this and see if he put it in right.'
http://www.justanswer.com/dodge/0gfbi-install-tps-1997-dodge-ram-1500-5-9liter-v-8-4x4.html
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: Andrewh] #992001
05/14/11 04:30 PM
05/14/11 04:30 PM
Missouri
mopar addict
mopar addict
Missouri
Will have him check it again...
BigBlock 74 Swinger
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: bb74swngr] #992002
05/14/11 06:19 PM
05/14/11 06:19 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sounds like a dirty throttle body. I see it all the time as when the battery is unhooked the IAC memory is lost and the PCM fogets the IAC steps. Best thing is to look at the IAC steps with a scanner (dont think thats the newer 2 wire style that dont use steps). The PCM is programmed to go to a certain amount of steps as per the eng temp and it doesn't know that the throttle body is dirty and it needs many more steps to keep it running. With the eng running warmed up and in park with everything turned off the IAC steps should be around 10 to 20. If its high like 60 or 70 the throttle body is dirty.
Or just clean the throttle body and throttle blade and see if it helps. Ron
Re: Need help w/97 Ram 1500 5.9L issue...please. [Re: 383man] #992003
05/14/11 09:07 PM
05/14/11 09:07 PM
Missouri
mopar addict
mopar addict
Missouri
Thanks for looking at this Ron:) My brother is a super clean freak, worse than me. He cleaned the throttle body to look like new. I feel your scanner idea may be key here. I will ask him if has had this done. He took it to the best, we live in the boonies, dodge dealership around and they said nothing was wrong. He needs another opinion and have the IAC/PCM rechecked per your suggestion. I will tell him.
Thanks!!!!
BigBlock 74 Swinger
