Ok, my brothers truck...1997 Ram 1500 5.9L.
Ran perfect but had a leaky head gasket, when putting it back together installed Comp cam (one cam before having to change computer), new lifters, new injectors, new TPS, new cam sensor, new crank censor, valves ground, a very meticulous craftsman. Now, it starts, runs, and idles perfect, back it up and pull it forward runs perfect, take it out on the street and drive to the stop sign and it dies, starts right up, drive it to the next stop and it dies, if he feathers the peddle it will keep running, drives it to work and gets 16mpg, if he slows to a stop at any time and it dies. When it starts to die as he is coming to a stop the rpm will go smoothly past the idle range right down to zero each time, it doesn't just die. He swapped computers with another 97 and does the same thing. He lives in Iowa and I live in Missouri, so this is a long distance diagnosis challenge.
We need help, please ask questions and I will try to answer...
Russ:)
