Difference between 70 and 71 Challenger hood edge trim? #991595
05/13/11 01:16 PM
05/13/11 01:16 PM
FL
71GoMango Offline OP
FL
Is there a difference? Thanks...Pics would help me too, so I can determine what I have and what I need to get...
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 71GoMango] #991596
05/13/11 01:40 PM
05/13/11 01:40 PM
Chapel Hill, NC
O
orangecrush Offline
orangecrush  Offline
O
Chapel Hill, NC
The 1970 trim bolts through the forward facing edge of the hood. The 1971 has a trim piece that has a lip that turns and goes under and is bolted to the underside edge of the hood. I believe that the 1970 also uses special attachments bolts too.
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: orangecrush] #991597
05/13/11 02:10 PM
05/13/11 02:10 PM
FL
FL
Ok, so I need to purchase a 70 style trim piece then...do they both have the same mold design? I want to make sure it will line up and match my 71 headlight bezels...Thanks!
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 71GoMango] #991598
05/13/11 10:20 PM
05/13/11 10:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you have a 70 or 71 Challenger?
71's have the lip on the bottom that would be correct for a 71.
Both styles will match up to 70 or 71 Bezels. For years people used 70 hood moldings on 71s as that is what Mopar superceded the molding to.
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 71GoMango] #991599
05/13/11 10:26 PM
05/13/11 10:26 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Maybe it was the SE, also had a wide bright trim (1-1.5" wide)?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: GO_Fish] #991600
05/13/11 10:47 PM
05/13/11 10:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That is 71 Challenger only hood periphery molding. No 71 SE's. And was not part of the A78 formal roof package on 1971 Challengers. It was a stand alone option ordered on roughly 10% of R/T and roughly 10% non R/T's.
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: autoxcuda] #991601
05/14/11 09:02 AM
05/14/11 09:02 AM
FL
FL
autoxcuda is right, as my car is a 71 Chally RT - A78 "Formal Roof" package car. I cant believe mine doesnt have it, because its a 2 fender tag car with Special order & "999" paint codes, along with every other molding upgrade, but not the wide fender molding. And to my knowledge its more like 3-4" wide molding, very cool looking, Ive even thought about getting some for mine anyway just cuz I like it...lol, but back to the original topic, I had to replace my hood, my car was stolen from previous owner and it was missing a tie rod and the thief didnt know it, so it took off into a tree when they started down the road...luckily it was just the hood and fender that took the hit...My hood is from a 70 Im pretty sure, seams like we had to fill the holes where 70's have the "DODGE" lettering on top, and mine has holes on the front edge as if to fasten the trim with...Will both work though was my question...Thanks
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 71GoMango] #991602
05/14/11 12:32 PM
05/14/11 12:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My 71 R/T has the wide hood molding, and A46 molding package, and rocker molding.
Yep, the 70 style will work on a 71.
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: autoxcuda] #991603
05/16/11 05:09 PM
05/16/11 05:09 PM
FL
FL
Do you know the exact code for the wide fender molding? Mine has:
M31, M42, M44, M91, M21, A46 & A78
Thanks!
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 71GoMango] #991604
05/19/11 12:52 AM
05/19/11 12:52 AM
blewbyu Offline
blewbyu  Offline
Thanks!
does the wide hood treatment fit on any 70-71 hood? or does have to have a special hood to mount the wide trim on it?
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: blewbyu] #991605
05/19/11 01:02 AM
05/19/11 01:02 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thanks!
M28
It requires large holes (5/16"-3/8" ?) be drilled on the top surface of the fenders & hood...
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: 1_WILD_RT] #991606
05/19/11 03:06 AM
05/19/11 03:06 AM
Southern CA
Colin Frolick Offline
Southern CA
just wanted to post a picture of a 1971 challenger
Re: Difference between 70 and 71 Challenger hood edge trim? [Re: blewbyu] #991607
05/22/11 04:57 PM
05/22/11 04:57 PM
WNY
slimert Offline
slimert  Offline
WNY
Thanks!
The wide lip moulding will only fit the 71 hood, the 70 hood has a different structural steel on the under side that a couple of the moulding studs will be short. I know
