trying to remove stick on wheel weight adhesive. #991434
05/13/11 02:08 AM
05/13/11 02:08 AM
Missouri
galen Online content OP
galen  Online Content OP
Missouri
Wheels are polished and trying not to scratch them removing the stick on weights. When I pull the weights the adhesive backing stays on the wheel. Whats best to strip it without any scratching?
Re: trying to remove stick on wheel weight adhesive. [Re: galen] #991435
05/13/11 02:12 AM
05/13/11 02:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Rag soaked with Goof-Off.. Let it lay on the goo for a minute then rub with your finger nail....
Re: trying to remove stick on wheel weight adhesive. [Re: 1_WILD_RT] #991436
05/13/11 05:52 AM
05/13/11 05:52 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Brake fluid and a ball of aluminum foil?
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: trying to remove stick on wheel weight adhesive. [Re: Pyper70] #991437
05/13/11 06:35 AM
05/13/11 06:35 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Laquer thinner
Re: trying to remove stick on wheel weight adhesive. [Re: 70HemiGTX] #991438
05/13/11 07:53 AM
05/13/11 07:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Laquer thinner
It'll work the best.
Re: trying to remove stick on wheel weight adhesive. [Re: Challenger 1] #991439
05/13/11 10:01 AM
05/13/11 10:01 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
becarfull but the best is gas on a rag .
1969 Dodge Charger 1969 Dodge Superbee
Re: trying to remove stick on wheel weight adhesive. [Re: cjs69mope] #991440
05/13/11 11:34 AM
05/13/11 11:34 AM
Gasoline or WD-40.
Re: trying to remove stick on wheel weight adhesive. #991441
05/13/11 09:03 PM
05/13/11 09:03 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Next Dimension brand "Brake and Parts cleaner"
in an aerosol can. It's fast drying,does not leave a residue,and is the only thing we use at our shop.
Our location in particular gets to work on numerous high dollar cars.All of these cars get tape on style weights.
DO NOT USE LACQUER THINNER !!!!!!
it will damage your tires.
Re: trying to remove stick on wheel weight adhesive. [Re: jcastle1] #991442
05/13/11 09:47 PM
05/13/11 09:47 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
3M general purpose adhesive remover.
Re: trying to remove stick on wheel weight adhesive. [Re: dartman366] #991443
05/13/11 10:04 PM
05/13/11 10:04 PM
Under My Car
Mopar_Country Offline
Under My Car
OOPS works well too.
Re: trying to remove stick on wheel weight adhesive. [Re: Mopar_Country] #991444
05/13/11 10:07 PM
05/13/11 10:07 PM
NY
W
WICKD6PK Offline
WICKD6PK  Offline
W
NY
Wd-40
Re: trying to remove stick on wheel weight adhesive. [Re: WICKD6PK] #991445
05/13/11 10:16 PM
05/13/11 10:16 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
WD-40 and a soft rag and some rubbing gets rid of left over "stick-um".
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: trying to remove stick on wheel weight adhesive. [Re: dartman366] #991446
05/14/11 12:15 AM
05/14/11 12:15 AM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The stuff is great.
Re: trying to remove stick on wheel weight adhesive. [Re: tmef] #991447
05/14/11 12:04 PM
05/14/11 12:04 PM
Cincinnati, Ohio
Cincinnati, Ohio
The stuff is great.
Sorry I have to disaggree with you. 2 nights ago I removed this sound insulation from a truck. There was a lot of foam and adhesive stuck to the firewall. I started with 3M, have used it many times before on smaller projects and I think is just OK. I guess it's safe on painted surfaces but it don't work near as well as lacquer thinner. I sprayed the 3m stuff about 6 times trying to get it to soften the adhesive but was slow to react. I finally broke out the lacquer thinner and soaked my rag with it and it did a much better job. It was way faster and didn't harm the paint on the firewall. It made it clean so my new insulation would stick better.
So good ole lacquer thinner comes through again, alway good to keep some on hand. My
Re: trying to remove stick on wheel weight adhesive. [Re: jcastle1] #991448
05/14/11 12:18 PM
05/14/11 12:18 PM
Kirkland, Washington
Pacnorthcuda Offline
How can lacquer thinner damage tires when it never touches them?
On a polished wheel Lacquer thinner is the way to go. Now if the wheel is clear coated/painted THEN be careful with solvents!
Re: trying to remove stick on wheel weight adhesive. [Re: Challenger 1] #991449
05/14/11 01:12 PM
05/14/11 01:12 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
The stuff is great.
The 3M adhesive remover I have is in a 1 pint metal container, kinda like what you would buy acetone in at the hardware store. This spray stuff I have never used.
