Re: trying to remove stick on wheel weight adhesive.
[Re: galen]
#991435
05/13/11 02:12 AM
05/13/11 02:12 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Rag soaked with Goof-Off.. Let it lay on the goo for a minute then rub with your finger nail....
[Re: Pyper70]
#991437
05/13/11 06:35 AM
05/13/11 06:35 AM
Posts: 2,363 PA
70HemiGTX
PA
[Re: Challenger 1]
#991439
05/13/11 10:01 AM
05/13/11 10:01 AM
Posts: 587 IL . usa
cjs69mope
IL . usa
becarfull but the best is gas on a rag .
1969 Dodge Charger
1969 Dodge Superbee
[Re: cjs69mope]
#991440
05/13/11 11:34 AM
05/13/11 11:34 AM
[Re: dartman366]
#991446
05/14/11 12:15 AM
05/14/11 12:15 AM
Posts: 672 Wichita, KS
tmef
Wichita, KS
3M general purpose adhesive remover.
The stuff is great.
[Re: tmef]
#991447
05/14/11 12:04 PM
05/14/11 12:04 PM
Challenger 1
Cincinnati, Ohio
The stuff is great.
Sorry I have to disaggree with you. 2 nights ago I removed this sound insulation from a truck. There was a lot of foam and adhesive stuck to the firewall. I started with 3M, have used it many times before on smaller projects and I think is just OK. I guess it's safe on painted surfaces but it don't work near as well as lacquer thinner. I sprayed the 3m stuff about 6 times trying to get it to soften the adhesive but was slow to react. I finally broke out the lacquer thinner and soaked my rag with it and it did a much better job. It was way faster and didn't harm the paint on the firewall. It made it clean so my new insulation would stick better.
So good ole lacquer thinner comes through again, alway good to keep some on hand. My
[Re: jcastle1]
#991448
05/14/11 12:18 PM
05/14/11 12:18 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
DO NOT USE LACQUER THINNER !!!!!! it will damage your tires.
How can lacquer thinner damage tires when it never touches them?
On a polished wheel Lacquer thinner is the way to go. Now if the wheel is clear coated/painted THEN be careful with solvents!
[Re: Challenger 1]
#991449
05/14/11 01:12 PM
05/14/11 01:12 PM
tmef
Wichita, KS
The stuff is great.
The 3M adhesive remover I have is in a 1 pint metal container, kinda like what you would buy acetone in at the hardware store. This spray stuff I have never used.
