12.2 brakes and 15" rims #990861
05/12/11 09:38 AM
05/12/11 09:38 AM
Lethbridge, AB, Canada
dangina Offline OP
dangina  Offline OP
has anyone ever confirmed that these rotors will or will not fit a 15" rim? - according to the fitment diagrams provided by wilwood they should fit under 15" rims...
Re: 12.2 brakes and 15" rims [Re: dangina] #990862
05/12/11 11:52 AM
05/12/11 11:52 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Which brake setup and which wheel?
Not all wheels are the same. Even steel wheels have differences.
- Stu Harmon
Re: 12.2 brakes and 15" rims [Re: dangina] #990863
05/12/11 12:03 PM
05/12/11 12:03 PM
AndyF Offline
AndyF  Offline
You'll have to try it to see. There is a possibility that a tiny caliper will fit with that size of rotor. But then again, who wants a tiny caliper?
Re: 12.2 brakes and 15" rims [Re: AndyF] #990864
05/12/11 01:46 PM
05/12/11 01:46 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
their rear disk, drum in hat style kit, which I think has 3/4" x 12.08" rotors and 4 piston dynalite calipers fits under my stock M body wheels.
2017 Grand Cherokee Overland
Re: 12.2 brakes and 15" rims [Re: patrick] #990865
05/13/11 03:01 AM
05/13/11 03:01 AM
dangina Offline OP
dangina  Offline OP
lookin to see if they fit my old 15x7 hurricane aluminum wheels trying to stuff the bigest rotors and calipers into them as possible - the jump from 11.75 to 12.2 isn't bad but the jump to 13" is almost double
plus if you run 13" you have to run 17" rims
problem is the rims I like are 15" and the 17" aluminum rims that are available for our cars are ugly as sin. The only 17" I found that I like are some nascar style rims but they are steel and weigh over 30+ lbs each.
I'll be daily driving my 72 runner as well as hitting as many autox and track days as possible - the trouble with the 11.75 I've read is that after a couple laps you get some pretty good brake fade which I can avoid going up to the bigger style rotors but wont be able to run my 15" for the street. i dunno how much of a gain performance wise i get by going from 11.75 to 12.2" rotors but its gotta be better i would think
just trying to get the best of both worlds i guess or if anyone can get these style of rims in 17" aluminum I will thank you!
http://www.diamondracingwheels.com/prochallenger.html
Re: 12.2 brakes and 15" rims [Re: dangina] #990866
05/13/11 05:45 AM
05/13/11 05:45 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I think you already have your answer. Those 16 and 17" versions ov the stocker rims are HEAVY. If they even have a 17" stock car rim. .. At a local tire shop i saw a single 16x8" stock car rim... pretty much like the ones pictured. I had a line on a set ov used but perfect 295/50/16 BFG's and figured mounting them on my Charger would be pretty rad... Brought my handydandy scale in there the next day... 32lbs.
OUCH.
No thank you. A 17" would be even more... double ouch when you realize these style rims can be had in wide 15" for as light as 19lbs...
Hmmm... which has me wondering about another tangent... Time for another thread.
Re: 12.2 brakes and 15" rims [Re: dangina] #990867
05/13/11 08:27 AM
05/13/11 08:27 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
for a hot street/across car, I'd use Dr. Diff's mustang parts based 13" front IIRC 12" rear kits.
are these close enough in style?
centerline GN wheels
or these?
or these
or
Re: 12.2 brakes and 15" rims [Re: Pale_Roader] #990868
05/13/11 11:30 AM
05/13/11 11:30 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
OUCH.
My 18" x 10" rims are only 19 pounds too...
(the front 18" x 8" are even lighter)
Re: 12.2 brakes and 15" rims [Re: dangina] #990869
05/13/11 11:42 AM
05/13/11 11:42 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
If you are worried about how it will do on the track, why not just step up to a larger wheel...you can take advantage of not only a better braking setup, but modern tire technology in 17" and 18" sizes?
Unless you were limited by the class you were running in, then you might just need to get more creative with your brake package.
I have a friend in Australia who road races a Torana (like mine) in a vintage type class and is limited to 15" tires..he does run a race compound/non-street tire at least.. And he needed as good a braking as possible so went with a custom setup using new AP Racing calipers and a 12.?" rotor from memory. The rotor offset pushes as far inward as possible to give him caliper clearance to the drop area of the wheel. He used the thickest rotor as possible as well..
Just some thoughts..if you think out of the box on your brake system you might be able to come up with something if you are stuck with only the 15" wheel. (but going larger does open up possibilities to easier brake packages and tire choices though)
Re: 12.2 brakes and 15" rims [Re: dangina] #990870
05/13/11 12:28 PM
05/13/11 12:28 PM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
There is more to resisting brake fad than simply going to larger rotors. Since the brake is a heat sink, you can increase the mass of the rotor to better disapate heat. 1.25 thick vs 1.0 makes a difference. There also is the ducting of air into the rotor to remove heat. You wouldn't expect a radiator to work effectively with no airflow, brake rotors work the same way. There are also pad compounds to consider. This is one of the reason to go to an aftermarket caliper like Wilwood or Viper. The variety of pad compounds allow you to tailer the heat range they are effective in. Compared to teh stock pad selection, this is the area to make your biggest gains.
FWIW, in autocross you actually can get away with a lot smaller and lighter rotor because the braking forces will be occurring at slowers speeds for less duration. Also consider that the nascar boys have been using 12.19
Re: 12.2 brakes and 15" rims [Re: OzHemi] #990871
05/13/11 01:49 PM
05/13/11 01:49 PM
dangina Offline OP
dangina  Offline OP
problem is that i found one or 2 17" rims that wouldnt look bad but then their offsets are limited to one or 2 sizes
I was leaning towards the wilwood setups as they have 3 wheel stud setups you can make if in case i do find a aftermarket set thats not 4x4.5"
I like the huge tire selection of of 17" rubber as well - just gonna have to keep looking - I found these rims last night after a couple hours of searching but then again the best size they got is a 16" rim...and 16" tire selection is almost as bad if not worse than a 15" tire....
http://www.etwheels.com/et/fueler.html
do you know what setup the nascar boys are using?
Re: 12.2 brakes and 15" rims [Re: dangina] #990872
05/13/11 03:46 PM
05/13/11 03:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
wheels.
Wheels.
WHEELS.
WHEELS!
IT'S WHEELS YOU GETTO THUGGIE WANNABE, WHEELS!!!!!!
not rims.
Sheesh.
17" wheels will get you more brake. If you are stuck on your 15s then you need to look at forced cooling for the brakes. Maybe you can find a better brake pad material to resist the fade (EBC Green Stuff maybe?).
Is it possible to find a bearing set taht will allow you to run the old C body or truck rotors that were 1.25" thick? Truck rotors would have to be early 80s or 70s. They changed the bolt pattern somewhere in the 80s.
- Stu Harmon
Re: 12.2 brakes and 15" rims [Re: OzHemi] #990873
05/13/11 07:22 PM
05/13/11 07:22 PM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Heh... 18x10"'s under 20lbs...??? i'm sure they were under $200 a wheel too...
Hows the saying go...??? Lightweight, cheap, strong... pick TWO.
Re: 12.2 brakes and 15" rims [Re: Pale_Roader] #990874
05/13/11 07:37 PM
05/13/11 07:37 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Actually...they were under $200 each.
(that was my price....retail on them was around $600 each. I paid $75 each for the forged centers and around $90 each for the outers.)
Being partly in the wheel business has it's bonuses now and then. Helps make up for dealing with some of the excruciating companies out there...
Re: 12.2 brakes and 15" rims [Re: OzHemi] #990875
05/14/11 06:56 AM
05/14/11 06:56 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Uh... i was being rather facetious... Last time i priced wheels like that they were around $4000 a set.
Maybe you could hook a guy up with some wide and light 17's...???
Re: 12.2 brakes and 15" rims [Re: Pale_Roader] #990876
05/16/11 09:06 PM
05/16/11 09:06 PM
dangina Offline OP
dangina  Offline OP
bump for some pics of good looking 17" rims on your rides - lets see what you guys got!
Re: 12.2 brakes and 15" rims [Re: dangina] #990877
05/17/11 11:59 AM
05/17/11 11:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
there's a big thread over in the general section from a month ago or so...search is your friend.
Re: 12.2 brakes and 15" rims [Re: patrick] #990878
05/17/11 12:03 PM
05/17/11 12:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
