How much can a header tube me manipulated? #990006
05/10/11 09:40 PM
05/10/11 09:40 PM
Long Island, NY.
Stroked65Belv Offline OP
Long Island, NY.
Hey guys, trying to install my Hooker Super Comps in my 65 B body! all good til I tried to tighten up the single tube that goes on driver side rear exhaust port. It obviously needs some manipulation of its 2" tube to clear the frame but how much can I beat it before I am wasting its performace end?
Its a 500" stroker with cast 452 heads. I know someone is gonna say TTI by the time I get to read a reply.
Re: How much can a header tube me manipulated? [Re: Stroked65Belv] #990007
05/10/11 09:51 PM
05/10/11 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not really much at all... your gonna need MOST of that
2"
Re: How much can a header tube me manipulated? [Re: Stroked65Belv] #990008
05/10/11 10:36 PM
05/10/11 10:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
If you cut the flange between the tubes, do you think it will help?
Re: How much can a header tube me manipulated? [Re: Bob_Coomer] #990009
05/10/11 11:10 PM
05/10/11 11:10 PM
Long Island, NY.
Long Island, NY.
I cant really do much with it. It is the tube that is the single and wraps around the torsion bar. It is shaped like a big "L" and slip fits into collector. Its touching the frame . I think it would need just under 1/2"to clear so the flange can sit properly on the head for a seal.
Re: How much can a header tube me manipulated? [Re: Stroked65Belv] #990010
05/10/11 11:15 PM
05/10/11 11:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What about making a alum spacer OR cut the tube and add
a little tubing
Re: How much can a header tube me manipulated? [Re: MR_P_BODY] #990011
05/11/11 12:40 AM
05/11/11 12:40 AM
Long Island, NY.
Long Island, NY.
I think it has to much tubing, but its another issue. Already ceramic coated, needs a good bashing.. Or just bite the TTI bullet. Looks like hours of work to re-install many times til fitment is clear them half a tube is wasted.
Re: How much can a header tube me manipulated? [Re: Stroked65Belv] #990012
05/11/11 12:46 AM
05/11/11 12:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For me its easy... I would cut and add/subtract the
amount of tubing to make it fit nice... since your taking
a single tube you can have it re-coated pretty cheap...
I'm not a fan of beating the tubes in
Re: How much can a header tube me manipulated? [Re: MR_P_BODY] #990013
05/11/11 12:54 AM
05/11/11 12:54 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would cut the pipe of just above where it is hitting the frame, bolt the top part on the head, put the bottom piece in the collector , rotate, cut and put in a bend or bends to piece together. Weld up and get it recoated. Got to be cheeper than a set of new headers, you might have the same problem with ITT's
Re: How much can a header tube me manipulated? [Re: rowin4] #990014
05/11/11 09:25 AM
05/11/11 09:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I would cut the pipe of just above where it is hitting the frame, bolt the top part on the head, put the bottom piece in the collector , rotate, cut and put in a bend or bends to piece together. Weld up and get it recoated. Got to be cheeper than a set of new headers, you might have the same problem with ITT's [/quote
I ended up cutting and rotating a tube on my Super Comps for my 64 Belvedere. These are strange headers. I've had 3 sets for early B-Bodys. The 1st set I had to make 1 left tube. The second set fit perfect (same car and cylinder heads). The 3rd set I made 1 tube a flattened a 2nd tube. Both were on plates and I could move the engine for the best fit. I agree I would remake the 1 tube.
