Anyone using HS rockers on Indy EZ heads #989006
05/09/11 08:31 PM
05/09/11 08:31 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Just wondering how well they mate up to the valve tip.
Re: Anyone using HS rockers on Indy EZ heads [Re: Stanton] #989007
05/09/11 08:33 PM
05/09/11 08:33 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Checked mine out on the geometry, looked like everything was in order....
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: Anyone using HS rockers on Indy EZ heads [Re: Stanton] #989008
05/09/11 09:17 PM
05/09/11 09:17 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
They typically fit very well on STD EZ's, and SR's, Need different for big EZ. Otherwise they are a good rocker for the EZ family.
RIP Monte Smith
Re: Anyone using HS rockers on Indy EZ heads [Re: Stanton] #989009
05/10/11 12:47 AM
05/10/11 12:47 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
My machinist added lash caps to get a better sweep of the roller tip. Here is the first picture. These are 1.5 ratio Harland Sharps.
Gart
Re: Anyone using HS rockers on Indy EZ heads [Re: Big Wedge] #989010
05/10/11 12:48 AM
05/10/11 12:48 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Here is the second picture.
Garth
Re: Anyone using HS rockers on Indy EZ heads [Re: Stanton] #989011
05/10/11 12:53 AM
05/10/11 12:53 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
Stanton- The Harland Sharps fit very well on the EZ's as far as alignment with the valve stem. I have the CnC'd 295's. However, I did have to have the pushrod holes in the head opened up to clear the pushrod (1.5 ratio) with a .620 lift cam and 3/8 pushrod. I think I would have been okay had I went with offset Intake rockers. The pushrods rubbed the intake runner. They did not bind but definately made solid contact with the runner. When I had the holes opened up the porosity in the casting allowed oil to seep through the intake runner. I ended up using silicon to embed the aluminum and have not had any problems. Food for thought! I was very impressed with the HS rockers!
Steve
