TRANNY FLUID #988570
05/09/11 01:00 AM
05/09/11 01:00 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Gonna change fluid in the cuda before it goes to the track and was wondering what everyone is running in there 727.
Re: TRANNY FLUID [Re: rickb67] #988571
05/09/11 01:06 AM
05/09/11 01:06 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Castrol Mercon Type F here
Re: TRANNY FLUID [Re: wheelsup68dart] #988572
05/09/11 01:30 AM
05/09/11 01:30 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
The last stuff I got was at TSC ....5 gallon pail of type-F.
Re: TRANNY FLUID [Re: dOoC] #988573
05/09/11 01:36 AM
05/09/11 01:36 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Dextron Mercon because John Cope tells me to....
Re: TRANNY FLUID [Re: rickb67] #988574
05/09/11 02:40 AM
05/09/11 02:40 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
I have heard Dexron from some trans builders and Type F from other builders. Maybe we should use 50% dexron and 50% type F. I have been using Mobil 1 ATF. It is Synthetic and for all transmissions, at least that is what I was told. I have aprox. 950 passes on the 727 in the Lebaron with same Mobil 1 fluid as the first pass. This is the beginning of 3rd season. No band adjustment or any maint. at all. Still cherry red and smelling sweet. Won S/P and made it to semis in FB this past sat night. 15 passes in 1 night. Now let me go find some wood to knock on.
Re: TRANNY FLUID [Re: rickb67] #988575
05/09/11 01:18 PM
05/09/11 01:18 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Type F.
Nautilus Racing-
Re: TRANNY FLUID [Re: rickb67] #988576
05/09/11 01:50 PM
05/09/11 01:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cheapo type F
Re: TRANNY FLUID [Re: MR_P_BODY] #988577
05/09/11 02:30 PM
05/09/11 02:30 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Mobil 1 syn. w/Lucas additive works well for me!!
Re: TRANNY FLUID [Re: MR_P_BODY] #988578
05/09/11 03:57 PM
05/09/11 03:57 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Cheapo type F
99% of trans builder's will say Type F. it has a bit of grit ,for lack if another term, that helps the clutches grab. since all brands meet the mfg. requirements the chaper the better works for me. I have been doing this for over 50 years and never seena failure do to the choice or cost of fluids I used.
home of the
Sox and Martin Hemi Duster
Re: TRANNY FLUID [Re: rickb67] #988579
05/10/11 09:51 AM
05/10/11 09:51 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Dextron III is what I run as recommended by my transmission builder. When I asked about running synthetic he said to save the money and change the fluid more often.
quote from the Valvoline web Q&A page
What is the difference between DexronIII/Mercon and type "F" transmission fluid?
The Valvoline Type F transmission fluid is a high quality NON-friction modified fluid. Dexron III/Mercon includes friction modifiers in the fluid additive package.
Re: TRANNY FLUID [Re: qwkmopardan] #988580
05/10/11 10:33 AM
05/10/11 10:33 AM
Guitar Jones Offline
So tell me how are you going to save money by changing the cheap regular fluid more often? Synthetic is the only way to go in my opinion. Having said that I use Hyundai SPIII in mine, it's synthetic and I get it for free, can't beat that with a stick.
Re: TRANNY FLUID [Re: Guitar Jones] #988581
05/10/11 10:42 AM
05/10/11 10:42 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Really depends on the application. We've tried everything from synthetic to John Deere tractor fluid and when it's burned it gets changed and it's burned a few times per race.
Re: TRANNY FLUID [Re: Guitar Jones] #988582
05/10/11 10:48 AM
05/10/11 10:48 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
Free is a very good price!
The thinking of the transmission builder is changing the fluid more often may not save more $$ with the coast of fluid. But a person may be more apt to change the fluid and "inspect" the pan for debris and for anything potentially going wrong = saving expensive hard parts and bearings. After the transmission issue I am currently dealing with and knowing how fast parts can add up. Prevention is going to be a priority when it comes to the 727 behind the 572. We have $3000. + invested in drums 6 pinion planetary gears bearings and more, building these cars aren't cheep by any means.
Re: TRANNY FLUID [Re: BobR] #988583
05/10/11 10:49 AM
05/10/11 10:49 AM
PA
moparacer Offline
moparacer  Offline
PA
I run dextron, type F, Mobil 1 synthetic and hydaulic oil in mine over the years and to be honest I didn't see any earth shattering advantages of one over the other besides the hydraulic oil lowering the stall a few hundred RPMs.
Never had failures with any of them. I think the most important factor is building the tranny right, then run whatever fluid you want....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: TRANNY FLUID [Re: moparacer] #988584
05/10/11 11:11 AM
05/10/11 11:11 AM
ky
68roadrunner Offline
ky
i heard the tractor fluid lowered the stall. by how much does it change it?
Re: TRANNY FLUID [Re: 68roadrunner] #988585
05/10/11 11:22 AM
05/10/11 11:22 AM
PA
moparacer Offline
moparacer  Offline
PA
I think it depends on how tight your converter is but I ran the heavier AW68 20 wt and it lowered it between 200-300 rpms.
Re: TRANNY FLUID [Re: moparacer] #988586
05/10/11 11:57 AM
05/10/11 11:57 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I just put the regular B&M in mine,because it is the type F fluid. At the cost of it I hope it is a better fluid. B&M will tell you unless you are running one of the new metric transmission don't run theirs or anyone else's synthetic fluid.
ATI has just come out with a synthetic fluid that you can use in the older transmissions.(ATI also said not to run synthetic before they come up with their own brand)
All of the above was told to me by techs at ATI(whose trans&converter I run)& B&M.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: TRANNY FLUID [Re: rickb67] #988587
05/10/11 04:58 PM
05/10/11 04:58 PM
Locomotion Offline
Locomotion  Offline
Synthetics offer extra insurance in extreme applications, like racing, mainly because of their extra resistance to heat and breakdown. I've been using Amsoil Supershift for years and my trans rebuilder said to keep using whatever I've been using.
Some fluids for street applications provide softer shifts for "comfort" and trans life in that particular application and certain "qualities" are necessary for proper computer control. Type F has been used in place of Dextron in race 727's for years because it shifts hard and holds well. Of course, it helps to use aftermarket bands and clutches also. Amsoil Supershift provides the best of everything as far as I'm concerned.
