ss springs -4.7 pinion angle #988538
05/08/11 11:30 PM
05/08/11 11:30 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Is -4.7 pinion angle too much for a street car with super stock springs? The -4.7 is from parallels and not driveshaft. Trying to decide if i should run it or shim it so it is less. Thanks
Re: ss springs -4.7 pinion angle [Re: mod381] #988539
05/09/11 09:06 PM
05/09/11 09:06 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Re: ss springs -4.7 pinion angle [Re: mod381] #988540
05/09/11 09:10 PM
05/09/11 09:10 PM
It's 4.7 degrees down from "horizontle"? I think you want to see how much lower it it in relation to that end of the shaft. What's the shaft angle?
Re: ss springs -4.7 pinion angle [Re: RapidRobert] #988541
05/09/11 09:21 PM
05/09/11 09:21 PM
wisconsin
mod381 Offline OP
mod381  Offline OP
wisconsin
Here is the specs of all,trans is down 1.1,driveshaft is down 4.5 and pinion is down 3.6. So this (i think) gives me a pinion angle of -4.7. The rear u-joint with a total of driveshaft and pinion is 8.1. I am thinking of adding a 2 degree shim to raise pinion,but I have heard that the super stock springs like more angle due to spring wrap?
Re: ss springs -4.7 pinion angle [Re: mod381] #988542
05/09/11 09:29 PM
05/09/11 09:29 PM
How much further "down" is the pinion than the rear end of the shaft. If the shaft is 2 down and the pinion is 5 down that'd b a "neg 3 deg" pinion angle
Re: ss springs -4.7 pinion angle [Re: RapidRobert] #988543
05/09/11 09:45 PM
05/09/11 09:45 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Your pinion angle is -2.5. I'd leave it alone unless you'll be putting slicks on it.
Re: ss springs -4.7 pinion angle [Re: mod381] #988544
05/09/11 11:56 PM
05/09/11 11:56 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Does your car develop a vibration on decereration or braking?
If your transmission slopes downward 1.1 degrees (toward the rear) and the pinion slopes downward 3.6 degrees (toward the front) you have a 4.7 degree negative pinion angle.
I usually consider 4 degrees maximum, but if your car does not vibrate, I wouldn't worry about it.
Re: ss springs -4.7 pinion angle [Re: DoctorDiff] #988545
05/10/11 11:04 AM
05/10/11 11:04 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Maximum for a street car? or for s/s springs...
