Re: ss springs -4.7 pinion angle
[Re: mod381]
#988540
05/09/11 09:10 PM
05/09/11 09:10 PM
RapidRobert
It's 4.7 degrees down from "horizontle"? I think you want to see how much lower it it in relation to that end of the shaft. What's the shaft angle?
[Re: mod381]
#988542
05/09/11 09:29 PM
05/09/11 09:29 PM
RapidRobert
How much further "down" is the pinion than the rear end of the shaft. If the shaft is 2 down and the pinion is 5 down that'd b a "neg 3 deg" pinion angle
[Re: RapidRobert]
#988543
05/09/11 09:45 PM
05/09/11 09:45 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Your pinion angle is -2.5. I'd leave it alone unless you'll be putting slicks on it.
[Re: DoctorDiff]
#988545
05/10/11 11:04 AM
05/10/11 11:04 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Does your car develop a vibration on decereration or braking?
If your transmission slopes downward 1.1 degrees (toward the rear) and the pinion slopes downward 3.6 degrees (toward the front) you have a 4.7 degree negative pinion angle.
I usually consider 4 degrees maximum, but if your car does not vibrate, I wouldn't worry about it.
Maximum for a street car? or for s/s springs...
