Whats the easiest way to remove a pinion nut #988517
05/08/11 11:25 PM
05/08/11 11:25 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I know these babies are torqued to 240 lbs. How do I remove one?
742 case.
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988518
05/08/11 11:28 PM
05/08/11 11:28 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
put breaker bar on nut...with breaker bar on ground...push car..
Tony
70 AARCuda Vitamin C
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988519
05/08/11 11:31 PM
05/08/11 11:31 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
IMpact gun.
BUT I am also going to make-up some of these ....
Re: Whats the easiest way to remove a pinion nut [Re: 70AARcuda] #988520
05/08/11 11:34 PM
05/08/11 11:34 PM
Puyallup, WA
Puyallup, WA
Pumpkin is not in car.... I have the yoke in my vice, and feel like I'm gonna rip the vice right off the bench!
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988521
05/08/11 11:37 PM
05/08/11 11:37 PM
Florida STAYcation
Florida STAYcation
Again .. the impact gun .. or THE TOOL
Or this one maybe ...
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988522
05/08/11 11:39 PM
05/08/11 11:39 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
Build a large box nut that has a long handle on it to hold the yoke.
Turn off the nut with an impack wrench.
Easier if you leave the re in the car until nut is loose.
Re: Whats the easiest way to remove a pinion nut [Re: BeEtLeJuIcE !] #988523
05/08/11 11:39 PM
05/08/11 11:39 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
If you don't have an impact gun or the 1 you have isn't strong enough, but you have a socket, maybe take it to a tire shop and see if the can break it loose for you. Les Schwab may not, but BigO Is usually pretty helpful around here.
Re: Whats the easiest way to remove a pinion nut [Re: None2Slow] #988524
05/08/11 11:44 PM
05/08/11 11:44 PM
Puyallup, WA
Puyallup, WA
I don't have air tools in my garage. I do have a buddy that's a tech at a Dodge dealer. I can run it out to him. I'll probably just do that.
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988525
05/09/11 12:33 AM
05/09/11 12:33 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
With it out, make it a 2 man job-- one guy on a big pipe wrench to hold the yoke, another on a breaker bar on the nut
This also works well with the carrier still installed and a one man operation, using the floor to hold the pipe wrench
Or... Take it to your buddy!!
**Photobucket sucks**
Re: Whats the easiest way to remove a pinion nut [Re: 70Cuda383] #988526
05/09/11 10:42 PM
05/09/11 10:42 PM
Puyallup, WA
Puyallup, WA
Got an impact gun on it today..... 5 seconds.
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988527
05/09/11 10:46 PM
05/09/11 10:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
.Here is what I used to pull the yolk. Works great on the pump in my 727 as well. The next post is a picture of the Pipe wrench in place.
Re: Whats the easiest way to remove a pinion nut [Re: bboogieart] #988528
05/09/11 10:53 PM
05/09/11 10:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The pipe wrench by myself. Breaker bar and it popped right off. Just rotated the pipe wrench untill it hit the floor pan. Although I really like the box that bolts to the pinion snubber boss.
Great idea.
I have mechanical Aptitude.
I can screw up anything.
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988529
05/09/11 11:36 PM
05/09/11 11:36 PM
What size is that nut?
Re: Whats the easiest way to remove a pinion nut [Re: RapidRobert] #988530
05/10/11 12:04 AM
05/10/11 12:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depends on the case number , one is 1 1/8 .
Re: Whats the easiest way to remove a pinion nut [Re: JohnRR] #988531
05/10/11 12:08 AM
05/10/11 12:08 AM
It's a 741
Re: Whats the easiest way to remove a pinion nut [Re: RapidRobert] #988532
05/10/11 06:18 AM
05/10/11 06:18 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
If it's really rusted, heating it up "cherry red" with the torches may be needed too.
Re: Whats the easiest way to remove a pinion nut [Re: StealthWedge67] #988533
05/10/11 06:51 AM
05/10/11 06:51 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
Electric impact gun, one of the best investments I've made. Quick and has lots of power.
My
Own
Personal
Adrenaline
Rush
Re: Whats the easiest way to remove a pinion nut [Re: Moparzrule] #988534
05/10/11 09:52 AM
05/10/11 09:52 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Or this.
Re: Whats the easiest way to remove a pinion nut [Re: 62maxwgn] #988535
05/10/11 11:49 AM
05/10/11 11:49 AM
Under My Car
Mopar_Country Offline
Under My Car
I fabbed these in short order when I rebuilt my chunk.
