Whats the easiest way to remove a pinion nut
#988517
05/08/11 11:25 PM
05/08/11 11:25 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I know these babies are torqued to 240 lbs. How do I remove one?
742 case.
Re: Whats the easiest way to remove a pinion nut
[Re: StealthWedge67]
#988518
05/08/11 11:28 PM
05/08/11 11:28 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
put breaker bar on nut...with breaker bar on ground...push car..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: None2Slow]
#988524
05/08/11 11:44 PM
05/08/11 11:44 PM
StealthWedge67
Puyallup, WA
I don't have air tools in my garage. I do have a buddy that's a tech at a Dodge dealer. I can run it out to him. I'll probably just do that.
#988525
05/09/11 12:33 AM
05/09/11 12:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
With it out, make it a 2 man job-- one guy on a big pipe wrench to hold the yoke, another on a breaker bar on the nut
This also works well with the carrier still installed and a one man operation, using the floor to hold the pipe wrench
Or... Take it to your buddy!!
**Photobucket sucks**
[Re: bboogieart]
#988528
05/09/11 10:53 PM
05/09/11 10:53 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
The pipe wrench by myself. Breaker bar and it popped right off. Just rotated the pipe wrench untill it hit the floor pan. Although I really like the box that bolts to the pinion snubber boss. Great idea.
I have mechanical Aptitude. I can screw up anything.
[Re: RapidRobert]
#988530
05/10/11 12:04 AM
05/10/11 12:04 AM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
What size is that nut?
Depends on the case number , one is 1 1/8 .
[Re: RapidRobert]
#988532
05/10/11 06:18 AM
05/10/11 06:18 AM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
If it's really rusted, heating it up "cherry red" with the torches may be needed too.
