Nasty Smelling Gear Lube
#98805
08/02/08 09:12 PM
08/02/08 09:12 PM
Posts: 11,269 Slantytown
DUFFMAN
Ask And Ye Shall Receive
Slantytown
I haven't smelled anything this nasty since I worked at a Jeep dealer and the parts manager opened a bottle of quadra-trac adative under my nose. This was not the same smell but just as bad.
It's a 1972 B-body with 8 1/4" rear. I took the cover off to drain the fluid and it almost smells burn't. Besides the normal greenish colored fluid there was a grayish "sludge" in it.
Do I have burnt gear lube or is there some sort of addative (limited slip) that makes it smell like that? Should I be concerned?
The car has 58k original miles but the rear end fluid has been changed because there was RTV on the diff cover. Also it's an open rear, not limited slip.
No longer taking $h!t from anyone!
Re: Nasty Smelling Gear Lube
[Re: Hotwheelsjr]
#98807
08/02/08 09:30 PM
08/02/08 09:30 PM
I don't even remember the name of it, anymore, but the ORIGINAL "whale oil" stuff for suregrip just smelled horrid.
[Re: Hotwheelsjr]
#98808
08/02/08 09:37 PM
08/02/08 09:37 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Rear gear lube just stinks...period.
How does it taste ?
[Re: DUFFMAN]
#98811
08/02/08 09:58 PM
08/02/08 09:58 PM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
I know what gear lube is supposed to smell like an it's like roses compared to this stuff. It's like an electrical fire, but 10X stronger.
[Re: Pat_Whalen]
#98816
08/03/08 07:53 AM
08/03/08 07:53 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Use a magnet and see if the sludge is ferrous, sticks to the magnet. If so it's metal, probably from the gears and/or bearings. If not then it's likely a contaminate.
[Re: Supercuda]
#98817
08/03/08 09:11 AM
08/03/08 09:11 AM
DUFFMAN
Slantytown
Maybe sludge isn't a good word to describe what I'm seeing. The gray is just as viscous as the rest, thats why I think it's some sort of addative. That and it smells almost as nasty of some addatives I've smelt in the past.
Whats odd is that it's open rear so I don't understand what or why someone would have used an addative.
[Re: DUFFMAN]
#98822
08/03/08 12:54 PM
08/03/08 12:54 PM
Posts: 857 charlotte,nc
pyp1000
charlotte,nc
That's easy to explain. sometimes people try that to quiet a noisy pinion or bearing.
