Nasty Smelling Gear Lube #98805
08/02/08 09:12 PM
08/02/08 09:12 PM
Slantytown
DUFFMAN Offline OP
Ask And Ye Shall Receive
DUFFMAN  Offline OP
Slantytown
I haven't smelled anything this nasty since I worked at a Jeep dealer and the parts manager opened a bottle of quadra-trac adative under my nose. This was not the same smell but just as bad.
It's a 1972 B-body with 8 1/4" rear. I took the cover off to drain the fluid and it almost smells burn't. Besides the normal greenish colored fluid there was a grayish "sludge" in it.
Do I have burnt gear lube or is there some sort of addative (limited slip) that makes it smell like that? Should I be concerned?
The car has 58k original miles but the rear end fluid has been changed because there was RTV on the diff cover. Also it's an open rear, not limited slip.
No longer taking $h!t from anyone!
Re: Nasty Smelling Gear Lube [Re: DUFFMAN] #98806
08/02/08 09:27 PM
08/02/08 09:27 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Rear gear lube just stinks...period.
Re: Nasty Smelling Gear Lube [Re: Hotwheelsjr] #98807
08/02/08 09:30 PM
08/02/08 09:30 PM
I don't even remember the name of it, anymore, but the ORIGINAL "whale oil" stuff for suregrip just smelled horrid.
Re: Nasty Smelling Gear Lube [Re: Hotwheelsjr] #98808
08/02/08 09:37 PM
08/02/08 09:37 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
How does it taste ?
Re: Nasty Smelling Gear Lube [Re: Hotwheelsjr] #98809
08/02/08 09:37 PM
08/02/08 09:37 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I love the smell of 80W90 gear oil. Call me
Re: Nasty Smelling Gear Lube [Re: Hotwheelsjr] #98810
08/02/08 09:57 PM
08/02/08 09:57 PM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
I know what gear lube is supposed to smell like an it's like roses compared to this stuff. It's like an electrical fire, but 10X stronger.
Re: Nasty Smelling Gear Lube [Re: DUFFMAN] #98811
08/02/08 09:58 PM
08/02/08 09:58 PM
Hotwheelsjr Offline
Hotwheelsjr  Offline
Re: Nasty Smelling Gear Lube [Re: DUFFMAN] #98812
08/03/08 12:07 AM
08/03/08 12:07 AM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Ah yes. Can't beat the smell of differential lube. Glad you like the odor
Re: Nasty Smelling Gear Lube [Re: 68Bullit] #98813
08/03/08 12:12 AM
08/03/08 12:12 AM
Oklahoma
Mopar72Man Offline
Mopar72Man  Offline
Oklahoma
good luck on trying to sleep in the same room with the wife after dealing with gear lube, and showering twice.
Re: Nasty Smelling Gear Lube [Re: 68Bullit] #98814
08/03/08 12:14 AM
08/03/08 12:14 AM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
Smells like victory! No. Wait. That's the smell of napalm in the morning. Wrong substance.
Gear lube just smells awful.
Re: Nasty Smelling Gear Lube [Re: pyp1000] #98815
08/03/08 12:49 AM
08/03/08 12:49 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
The greyish sludge sounds like it might be water/moisture that has gotten in there over time...
Re: Nasty Smelling Gear Lube [Re: Pat_Whalen] #98816
08/03/08 07:53 AM
08/03/08 07:53 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Use a magnet and see if the sludge is ferrous, sticks to the magnet. If so it's metal, probably from the gears and/or bearings. If not then it's likely a contaminate.
Don't be the exception.
Re: Nasty Smelling Gear Lube [Re: Supercuda] #98817
08/03/08 09:11 AM
08/03/08 09:11 AM
Slantytown
DUFFMAN Offline OP
DUFFMAN  Offline OP
Slantytown
Maybe sludge isn't a good word to describe what I'm seeing. The gray is just as viscous as the rest, thats why I think it's some sort of addative. That and it smells almost as nasty of some addatives I've smelt in the past.
Whats odd is that it's open rear so I don't understand what or why someone would have used an addative.
Re: Nasty Smelling Gear Lube [Re: DUFFMAN] #98818
08/03/08 09:53 AM
08/03/08 09:53 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Skunk Juice!!!! Is what we affectionately call it. Try and get that stuff off you if you were unfortunate enough to be under it when you opened it.
Re: Nasty Smelling Gear Lube [Re: Dragula] #98819
08/03/08 10:39 AM
08/03/08 10:39 AM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
My wife threw away one of my best work t-shirts when I got the stuff on it. She said she didn't want it stinking up the house....Shhhhsh women.
Re: Nasty Smelling Gear Lube [Re: Dragula] #98820
08/03/08 11:08 AM
08/03/08 11:08 AM
Britton, MI
GTXWagon Offline
GTXWagon  Offline
Britton, MI
We call it "Liquid Death" ......
Re: Nasty Smelling Gear Lube [Re: GTXWagon] #98821
08/03/08 12:51 PM
08/03/08 12:51 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
When a buddy got married, our honeymoon joke was to soak a rag in "Skunk Oil" and put it under the rear seat of the car that the were driving to Niagra Falls.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Nasty Smelling Gear Lube [Re: DUFFMAN] #98822
08/03/08 12:54 PM
08/03/08 12:54 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
That's easy to explain. sometimes people try that to quiet a noisy pinion or bearing.
