WHAT SIZE POWER VALVES SHOULD I USE? #987613
05/07/11 02:28 PM
05/07/11 02:28 PM
Hermiston Oregon
mopar_leaner Offline OP
Hermiston Oregon
I'm working on a tunnel rammed "stock" 318 with a pair of 1850 holley 600's on it. I just need to get it running ok, nothing great. I'm thinking because the engine is stock, I might need help keep the power valves closed longer so it would foul the plugs.
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: mopar_leaner] #987614
05/07/11 05:52 PM
05/07/11 05:52 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Did I read this right? A STOCK 318 with 1200 cfm of carburetors?
You DO realize that even most 440s only had a 675 cfm 4 barrel?
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: Kern Dog] #987615
05/07/11 05:55 PM
05/07/11 05:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd think ONE holley would be plenty for a stock 318. And if you ran ONE stock PV I'd guess a 6.5 would do the trick. Maybe even higher. a tunnel ram on a stock engine isn't going to wrok very well.
Coming soon!!!!
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: Mr.Yuck] #987616
05/07/11 06:49 PM
05/07/11 06:49 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Power valves will probably be the least of your issues with that setup. If you don't have a really good ignition on it, it's gonna foul plugs anyway.
I'm guessing it's also an automatic with a stock converter and 3.23 or higher gears?
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: slantzilla] #987617
05/08/11 09:43 AM
05/08/11 09:43 AM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
i agree that the combo sounds a bit strange.
as far as the power valves go.....you need a vacume gauge to properly size the power valve. do a google search and you will find the proper procedure for selecting a power valve.
unions....the folks who brought you the weekend!
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: mopar_leaner] #987618
05/08/11 09:51 AM
05/08/11 09:51 AM
Might start w 1/2 of what your manifold vacuum reading is in drive at idle
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: mopar_leaner] #987619
05/08/11 01:25 PM
05/08/11 01:25 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Holly says to take a vacuum reading at idle in drive or in neutral if you have a manual trans. Divide by 2. the result is the power valve size. If you end up with a number between two power valve sizes, use the lower number.
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: rbstroker] #987620
05/08/11 04:41 PM
05/08/11 04:41 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
If you get those carbs in tune, It will run fine, even on a stockish 318, A single carb set-up or smallers "carbs" of coarse would run better, but you won't have the "WOW" factor which i'm sure thats what your after & you already have the 600s, You may also need to jet those carbs down a bit.
The 1st. thing i would do is make sure the ignition is strong & in good shape, & get a quick timing curve in it with as much initual timing as possible, a good adj. dist. helps wonders with setting up the curve & RPM your after for total timing, I like the MSD 8534 Billet. Its simple, then run a digital box or a Mallory Highfire 6853M 6AL.
http://www.jegs.com/i/MSD+Ignition/121/8534/10002/-1
http://www.jegs.com/i/Mallory/650/6853M/10002/-1
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: WHAT SIZE POWER VALVES SHOULD I USE? [Re: joedust451] #987621
05/08/11 09:18 PM
05/08/11 09:18 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I would be looking at 10.5 PV's to start with if it is a healthy stock 318. Hopefully you have carb's with removable air bleeds because you will most likely need to lean out the idle circuit a ton with two carbs...unless the massive plenum area makes up for it. Who knows, with some tuning it might run fine.
