WHAT SIZE POWER VALVES SHOULD I USE?
#987613
05/07/11 02:28 PM
05/07/11 02:28 PM
Posts: 751 Hermiston Oregon
mopar_leaner
Hermiston Oregon
I'm working on a tunnel rammed "stock" 318 with a pair of 1850 holley 600's on it. I just need to get it running ok, nothing great. I'm thinking because the engine is stock, I might need help keep the power valves closed longer so it would foul the plugs.
Re: WHAT SIZE POWER VALVES SHOULD I USE?
[Re: Mr.Yuck]
#987616
05/07/11 06:49 PM
05/07/11 06:49 PM
Posts: 20,165 Park Forest, IL
slantzilla
Park Forest, IL
Power valves will probably be the least of your issues with that setup. If you don't have a really good ignition on it, it's gonna foul plugs anyway.
I'm guessing it's also an automatic with a stock converter and 3.23 or higher gears?
[Re: slantzilla]
#987617
05/08/11 09:43 AM
05/08/11 09:43 AM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
i agree that the combo sounds a bit strange.
as far as the power valves go.....you need a vacume gauge to properly size the power valve. do a google search and you will find the proper procedure for selecting a power valve.
unions....the folks who brought you the weekend!
[Re: rbstroker]
#987620
05/08/11 04:41 PM
05/08/11 04:41 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
If you get those carbs in tune, It will run fine, even on a stockish 318, A single carb set-up or smallers "carbs" of coarse would run better, but you won't have the "WOW" factor which i'm sure thats what your after & you already have the 600s, You may also need to jet those carbs down a bit. The 1st. thing i would do is make sure the ignition is strong & in good shape, & get a quick timing curve in it with as much initual timing as possible, a good adj. dist. helps wonders with setting up the curve & RPM your after for total timing, I like the MSD 8534 Billet. Its simple, then run a digital box or a Mallory Highfire 6853M 6AL. http://www.jegs.com/i/MSD+Ignition/121/8534/10002/-1http://www.jegs.com/i/Mallory/650/6853M/10002/-1
