A-Body Tire Size #987439
05/06/11 11:04 PM
05/06/11 11:04 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
What's the stock or largest tires and backspacing I can run on the front and rear of a 68 Dodge Dart without any rubbing or modifications to the wheel well? Thank you!
Re: A-Body Tire Size [Re: MuuMuu101] #987440
05/07/11 12:53 AM
05/07/11 12:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Come on, MuuMuu......You have been reading and posting long enough to know that you MUST include more info for anyone to be helpful! Stock axle and brakes? Front BBP disc conversion?
Re: A-Body Tire Size [Re: MuuMuu101] #987441
05/07/11 05:06 PM
05/07/11 05:06 PM
san diego
JonsGottaDusta Offline
san diego
I run a 245/45r17 on a 17x8 wheel.
Re: A-Body Tire Size [Re: JonsGottaDusta] #987442
05/07/11 05:20 PM
05/07/11 05:20 PM
SoCal
SoCal
Ok there's a start. Is that front and back? Also what's your offset or backspacing?
Re: A-Body Tire Size [Re: MuuMuu101] #987443
05/07/11 05:26 PM
05/07/11 05:26 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Stock for stock Dusters can take more rear tire than a Dart.
This post on abodiesonly has a lot of tire and rim combos:
http://www.forabodiesonly.com/mopar/showthread.php?t=14254
Re: A-Body Tire Size [Re: dustergirl340] #987444
05/07/11 05:30 PM
05/07/11 05:30 PM
SoCal
SoCal
Thanks Dustergirl
I was looking at summit racing for some rims and I saw a couple I liked that were 17x7's with a 5.575 backspacing and if I decide to get them in the future, I don't want to have issues with rubbing and clearance. I was thinking about getting a Hotchkis TVS system later on and of course a Front and Rear disc brake conversion set (looking into Willwoods).
If necessary, couldn't I get wheel spacers just to move them over? Will they ad any extra stress to the car's frame, suspension, or axle?
Re: A-Body Tire Size [Re: MuuMuu101] #987445
05/08/11 12:30 AM
05/08/11 12:30 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Thanks Dustergirl
No way will a 5.575 backspacing work. 4.5 is about the most you can go with everything in the stock location. Even then it will be close to the spring.
Re: A-Body Tire Size [Re: forphorty] #987446
05/08/11 01:23 AM
05/08/11 01:23 AM
SoCal
SoCal
Thanks Dustergirl
Okie Dokie. So then they are out of the picture. Thank you!
Re: A-Body Tire Size [Re: MuuMuu101] #987447
05/08/11 03:33 AM
05/08/11 03:33 AM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Agreed, I believe I was running 15x8 with 4.5 BS on my 70 Dart with stock leaf location 235/60/15 bfg drag radials. May have been 15x7's
On my Demon I am running 17x8 with 4 1/2 bs with a 245/45/17 tire.
Re: A-Body Tire Size [Re: wheelsup68dart] #987448
05/08/11 02:24 PM
05/08/11 02:24 PM
SoCal
SoCal
Now do you have a 7 or 8 tire width in the front as well?
Re: A-Body Tire Size [Re: MuuMuu101] #987449
05/08/11 09:18 PM
05/08/11 09:18 PM
Columbus, Ohio
Columbus, Ohio
Fronts are 16" 215/55/16 and not sure on 7 or 8" but I know I don't have enough backspacing as I trimmed the front lower fender a bit(not a show car)
Re: A-Body Tire Size [Re: wheelsup68dart] #987450
05/08/11 09:43 PM
05/08/11 09:43 PM
SoCal
SoCal
Maybe I will go for some 15's with some good tires for some good grip. It seems like most guys have 15x6's in the front with 205/60/15's and 15x7 or 8's with 235/60/15's with an unmodified suspension. The only thing is I would like a great disc break setup to really stop the car. I think willwood does make breaks to fit 15's. I think they are like half the price of the 17's
