Re: A-Body Tire Size
[Re: JonsGottaDusta]
#987442
05/07/11 05:20 PM
05/07/11 05:20 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
I run a 245/45r17 on a 17x8 wheel.
Ok there's a start. Is that front and back? Also what's your offset or backspacing?
[Re: dustergirl340]
#987444
05/07/11 05:30 PM
05/07/11 05:30 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Stock for stock Dusters can take more rear tire than a Dart.
This post on abodiesonly has a lot of tire and rim combos:
http://www.forabodiesonly.com/mopar/showthread.php?t=14254
Thanks Dustergirl
I was looking at summit racing for some rims and I saw a couple I liked that were 17x7's with a 5.575 backspacing and if I decide to get them in the future, I don't want to have issues with rubbing and clearance. I was thinking about getting a Hotchkis TVS system later on and of course a Front and Rear disc brake conversion set (looking into Willwoods).
If necessary, couldn't I get wheel spacers just to move them over? Will they ad any extra stress to the car's frame, suspension, or axle?
[Re: MuuMuu101]
#987445
05/08/11 12:30 AM
05/08/11 12:30 AM
Posts: 1,458 oklahoma
forphorty
oklahoma
Thanks Dustergirl
No way will a 5.575 backspacing work. 4.5 is about the most you can go with everything in the stock location. Even then it will be close to the spring.
[Re: forphorty]
#987446
05/08/11 01:23 AM
05/08/11 01:23 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Thanks Dustergirl
Okie Dokie. So then they are out of the picture. Thank you!
[Re: MuuMuu101]
#987449
05/08/11 09:18 PM
05/08/11 09:18 PM
Posts: 4,628 Columbus, Ohio
wheelsup68dart
Columbus, Ohio
Now do you have a 7 or 8 tire width in the front as well?
Fronts are 16" 215/55/16 and not sure on 7 or 8" but I know I don't have enough backspacing as I trimmed the front lower fender a bit(not a show car)
