More big block drama...cylinder head dowels #987422
05/06/11 10:54 PM
05/06/11 10:54 PM
California
court9155 Offline OP
California
67 charger
Re: More big block drama...cylinder head dowels [Re: court9155] #987423
05/06/11 11:49 PM
05/06/11 11:49 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
yep
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: More big block drama...cylinder head dowels [Re: court9155] #987424
05/07/11 01:25 AM
05/07/11 01:25 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
If you have an automotive machine shop in the area, they may have them if you need them right away (or possibly free, depending on the shop).
Re: More big block drama...cylinder head dowels [Re: Exit1965] #987425
05/07/11 01:27 AM
05/07/11 01:27 AM
California
California
Thanks, I have checked all the local parts stores and the one inadequate local machine shop...no avail..
summit it is
67 charger
Re: More big block drama...cylinder head dowels [Re: court9155] #987426
05/07/11 01:55 AM
05/07/11 01:55 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just a heads up please place a head on the dowels to make sure the heads set flush on the block after installing new dowels. If the heads and or block have been cut you may have to file down the dowels so they don't bottom out on the heads. 30+ years ago I cracked a very nice ported set of 906 heads because I failed to check this out. lesson learned.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: More big block drama...cylinder head dowels [Re: court9155] #987427
05/07/11 05:16 AM
05/07/11 05:16 AM
Delray beach, Florida
P
Performance Only Offline
P
if your working on a big block, like the thread title indicates, those are the wrong dowels.
the link you posted is for small block dowels.
machine shop owner and engine builder
Re: More big block drama...cylinder head dowels [Re: Performance Only] #987428
05/07/11 06:09 AM
05/07/11 06:09 AM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
^This.....Use the Moroso offset dowels (37900) and move the heads up towards the valley a bit.
Re: More big block drama...cylinder head dowels [Re: abodiesonly1] #987429
05/07/11 11:58 AM
05/07/11 11:58 AM
California
California
dammit....
well how important is it to use these dowels?
67 charger
Re: More big block drama...cylinder head dowels [Re: court9155] #987430
05/07/11 12:09 PM
05/07/11 12:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I've always gotten by with standard pins which mopar sells in block hardware kit. Or at least used to. I believe they are .250" Could be mistaken.
Re: More big block drama...cylinder head dowels [Re: buildanother] #987431
05/07/11 12:13 PM
05/07/11 12:13 PM
California
California
Yeah but they want $106 for that kit...f that..
http://www.summitracing.com/parts/DCC-5249259/
67 charger
Re: More big block drama...cylinder head dowels [Re: buildanother] #987432
05/07/11 12:19 PM
05/07/11 12:19 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
They only measure .247".
Mopar part #141215.
Re: More big block drama...cylinder head dowels [Re: Performance Only] #987433
05/07/11 12:20 PM
05/07/11 12:20 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
[Hint] The guy that told you the Chevy dowels were wrong (Performance Only) almost certainly has the correct ones in stock. [/Hint]
Re: More big block drama...cylinder head dowels [Re: court9155] #987434
05/07/11 12:20 PM
05/07/11 12:20 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: More big block drama...cylinder head dowels [Re: OzHemi] #987435
05/07/11 12:36 PM
05/07/11 12:36 PM
California
California
Thanks! You guys are great! Gotta love this site!
67 charger
Re: More big block drama...cylinder head dowels [Re: court9155] #987436
05/07/11 12:59 PM
05/07/11 12:59 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
Are you guys serious. Go measure the shank on a 1/4" bolt.
Re: More big block drama...cylinder head dowels [Re: abodiesonly1] #987437
05/10/11 07:58 AM
05/10/11 07:58 AM
PA
BTTG Offline
BTTG  Offline
PA
Is this 0.03 inch shift of the head upward actually effective or a gimmick? Also is this shift small enough that the intake will still seal well?
Re: More big block drama...cylinder head dowels [Re: BSB67] #987438
05/10/11 11:02 AM
05/10/11 11:02 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
