Re: Burnouts,exploding trannys and lauch proceedure
[Re: shoebox]
#987190
05/06/11 03:26 PM
05/06/11 03:26 PM
Posts: 2,512 PA
moparacer
PA
On the burnout, start in second and shift to high, come out of the water and don't let the tires grab hard...
Pretty much it...
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#987193
05/06/11 04:00 PM
05/06/11 04:00 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Pretty much it...
This is wrong. Your automatic will start out in 1st by itself. Therefore you must start in low to apply the band, then go in to 2nd and don't look back. I've got alot of runs on mine, same same, and still works like day one. (10 yrs, 4 championships...blah blah)
[Re: shoebox]
#987194
05/06/11 04:03 PM
05/06/11 04:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Leave in manual low?
No, put the shifter in second then hit the pedal pretty good... its going to start out in low then it'll shift on its own pretty quick then get the revs up a bit more and then shift into drive... let it burn forward a few feet then back off the pedal... pull to the line... you can manually shift it if you want or put it in drive... your choice
[Re: MR_P_BODY]
#987195
05/06/11 04:12 PM
05/06/11 04:12 PM
RemCharger
Sk. Canada
I don't agree with this(Respectfully) because you will be starting out against the sprag alone. Put in low and you will apply the low band, therefore helping the sprag hold all of the torque you are putting to it , trying to get the tires lit. Remember, this is not a mv body. Please explain if I'm off base here.
[Re: RemCharger]
#987196
05/06/11 04:31 PM
05/06/11 04:31 PM
Posts: 2,512 PA
moparacer
PA
With an hand grenade 727 if I COULDNT start out in second, I would switch to a manual valve body that COULD... All I am saying....
[Re: shoebox]
#987197
05/06/11 04:37 PM
05/06/11 04:37 PM
Posts: 30,444 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I need the cheaper option.
The CHEAPER ... in the long run .... is a aftermarket front drum. THEN the trans can NOT blow-up. The sprag might still fail .... but then all you have to R&R is that one item.
IF you go the route of all then fancy shields and blankets .... the problem then ... is IF the trans blows-up and then is successfully contained .... the trans then is TOAST ...and maybe even the converter.
[Re: RemCharger]
#987198
05/06/11 04:59 PM
05/06/11 04:59 PM
Posts: 5,080 organ
maximum entropy
organ
i'm with remcharger on this. anything you can do to protect the sprag should be implemented. manual low may seem redundant if it jumps right into second, but weird things happen. a lot of stuff blows up in the burnout box. i ran an automatic valve body for a long time, and i always started in manual low, whether in the burnout box, or on the track.
[Re: maximum entropy]
#987199
05/06/11 05:23 PM
05/06/11 05:23 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
I had a auto V/B in mine for a couple years. put it in 2 and put it to the wood till it hits second then come out of the water.. and if your going to shift it, start in first and go through the gears.. the stock drums went through a lot during the 60's and 70's in top fuel cars... and i have only seen 2 come apart that rally blew up... so drive it like u stole it. By the way what combo you have?
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: shoebox]
#987201
05/06/11 10:42 PM
05/06/11 10:42 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
To the best of my knowledge, the Transgo TF-2 (auto vb) is NOT a low-band apply modification. To get the low band to apply, you still have to manually shift the trans into low. For this reason, I would always manually shift the trans into low when starting a burnout, OR and especially when launching the car. Otherwise, you're relying on the sprag to hold 1st gear. (at least this is how my trans builder explained it to me... ) I have the TF-2 vb. I start my burnout in 1st and quickly move to second as soon as I get the tires rotating along. Try to avoid "catching" the tires while still under power when pulling out. This procedure seems to be working for my 727.
[Re: dOoC]
#987202
05/06/11 11:32 PM
05/06/11 11:32 PM
Posts: 415 Peru
cbarracuda
Peru
Are you sure? Have been racing so many years with factory drums
[Re: cbarracuda]
#987203
05/07/11 12:42 AM
05/07/11 12:42 AM
dOoC
Florida STAYcation
I too have also had good-luck with the OEM drums ... but I have never broken a sprag. And to be perfectly honest ...I potentially have a WORSEer problem than 99.9% of the others ... I drilled the band surface THROUGH TO THE CLUTCHES (like a vented rotor) as an experiment way back when. If my sprag failed ...I am sure that my drum would come-apart sooner(lower RPM) than a stocker.
And the more I think about all this ... the more I am thinking about changing THAT DRUM before I see any other drag-strip or street action. It is a 65 trans in my 62 ..and that stuff is getting harder to find now..... ESPECIALLY that 65 Race Hemi converter.
THAT THING has been a sweetheart. SOMETHING about that converter has me keeping putting that back in the car for years ...even though I had a good Fairbanks WD deal ...way-back-when ....
[Re: shoebox]
#987204
05/07/11 01:01 AM
05/07/11 01:01 AM
Posts: 7,506 Az
Crizila
Az
How you do your burn out will depend on how your trans is set up. I run a 727 with a 4 clutch steel front drum and a Turbo-Action Cheetah Pro street valve body - has low band apply and will upshift automatically in drive. I pull in to the water in drive ( 1st gear ). With the line lock on, I dip in to the throttle and let the trans upshift in to 3rd. I then release the line lock and feed in more throttle as the car powers out of the water - sometimes referred to as a "power burn out". As the tires get traction and the motor starts to lug down, I ease out of the throttle around 20 feet in front of the staging lights. As I come to a stop, I dump it in neutral, give it a blip or two to make sure the motor is clean and the secondary squirters are fuel charged, and I am ready to go. Again, this is just my proceedure. http://s79.photobucket.com/albums/j160/jcailey/?action=view¤t=MOV01123.mp4
Fastest 300
[Re: Crizila]
#987205
05/07/11 01:17 AM
05/07/11 01:17 AM
Posts: 415 Peru
cbarracuda
Peru
[Re: CrazyD]
#987208
05/07/11 10:29 AM
05/07/11 10:29 AM
MR_P_BODY
If it was a MANUAL valve body 727, burnout should start in what gear?
2nd or high gear... if you have a light car or plenty of power just start in high... your trying to get heat into them and the faster tire RPM does it quicker
