Page 1 of 3 1 2 3
Burnouts,exploding trannys and lauch proceedure #987189
05/06/11 03:23 PM
05/06/11 03:23 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Another thread here got me thinking about my transmission and
How im using it. Stock 727BB with trans go shift kit...still has auto
Function etc. Tell me how to properly burnout and launch the car
So the drum wont poof!! Also can i get blanket or do i need a
Shield?? I need the cheaper option. Ive only dont a couple burnouts
With the car years ago, i dont remember ifi used manual low. Can i
Launch in manual low?
74 dart sport 440 www.Csucarbs.com
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987190
05/06/11 03:26 PM
05/06/11 03:26 PM
PA
moparacer Offline
moparacer  Offline
PA
On the burnout, start in second and shift to high, come out of the water and don't let the tires grab hard...
Pretty much it...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Burnouts,exploding trannys and lauch proceedure [Re: moparacer] #987191
05/06/11 03:42 PM
05/06/11 03:42 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Leave in manual low?
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987192
05/06/11 03:57 PM
05/06/11 03:57 PM
okla.
sam64 Offline
sam64  Offline
okla.
yes launch in manual low,or you can just leave it in drive and let it shift itself.
Re: Burnouts,exploding trannys and lauch proceedure [Re: moparacer] #987193
05/06/11 04:00 PM
05/06/11 04:00 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Pretty much it...
This is wrong.
Your automatic will start out in 1st by itself. Therefore you must start in low to apply the band, then go in to 2nd and don't look back.
I've got alot of runs on mine, same same, and still works like day one. (10 yrs, 4 championships...blah blah)
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987194
05/06/11 04:03 PM
05/06/11 04:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No, put the shifter in second then hit the pedal pretty
good... its going to start out in low then it'll
shift on its own pretty quick then get the revs up
a bit more and then shift into drive... let it burn
forward a few feet then back off the pedal... pull to
the line... you can manually shift it if you want or
put it in drive... your choice
Re: Burnouts,exploding trannys and lauch proceedure [Re: MR_P_BODY] #987195
05/06/11 04:12 PM
05/06/11 04:12 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I don't agree with this(Respectfully) because you will be starting out against the sprag alone. Put in low and you will apply the low band, therefore helping the sprag hold all of the torque you are putting to it , trying to get the tires lit.
Remember, this is not a mv body.
Please explain if I'm off base here.
Re: Burnouts,exploding trannys and lauch proceedure [Re: RemCharger] #987196
05/06/11 04:31 PM
05/06/11 04:31 PM
PA
moparacer Offline
moparacer  Offline
PA
With an hand grenade 727 if I COULDNT start out in second, I would switch to a manual valve body that COULD...
All I am saying....
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987197
05/06/11 04:37 PM
05/06/11 04:37 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
The CHEAPER ... in the long run .... is a aftermarket front drum. THEN the trans can NOT blow-up. The sprag might still fail .... but then all you have to R&R is that one item.
IF you go the route of all then fancy shields and blankets .... the problem then ... is IF the trans blows-up and then is successfully contained .... the trans then is TOAST ...and maybe even the converter.
Re: Burnouts,exploding trannys and lauch proceedure [Re: RemCharger] #987198
05/06/11 04:59 PM
05/06/11 04:59 PM
organ
maximum entropy Offline
organ
i'm with remcharger on this. anything you can do to protect the sprag should be implemented. manual low may seem redundant if it jumps right into second, but weird things happen. a lot of stuff blows up in the burnout box. i ran an automatic valve body for a long time, and i always started in manual low, whether in the burnout box, or on the track.
Re: Burnouts,exploding trannys and lauch proceedure [Re: maximum entropy] #987199
05/06/11 05:23 PM
05/06/11 05:23 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
I had a auto V/B in mine for a couple years. put it in 2 and put it to the wood till it hits second then come out of the water.. and if your going to shift it, start in first and go through the gears.. the stock drums went through a lot during the 60's and 70's in top fuel cars... and i have only seen 2 come apart that rally blew up... so drive it like u stole it.
By the way what combo you have?
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Burnouts,exploding trannys and lauch proceedure [Re: kissmyaspen] #987200
05/06/11 06:00 PM
05/06/11 06:00 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Who me? Probably a 530hp 440
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987201
05/06/11 10:42 PM
05/06/11 10:42 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
To the best of my knowledge, the Transgo TF-2 (auto vb) is NOT a low-band apply modification. To get the low band to apply, you still have to manually shift the trans into low. For this reason, I would always manually shift the trans into low when starting a burnout, OR and especially when launching the car. Otherwise, you're relying on the sprag to hold 1st gear.
(at least this is how my trans builder explained it to me... )
I have the TF-2 vb. I start my burnout in 1st and quickly move to second as soon as I get the tires rotating along. Try to avoid "catching" the tires while still under power when pulling out. This procedure seems to be working for my 727.
Re: Burnouts,exploding trannys and lauch proceedure [Re: dOoC] #987202
05/06/11 11:32 PM
05/06/11 11:32 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Are you sure? Have been racing so many years with factory drums
Re: Burnouts,exploding trannys and lauch proceedure [Re: cbarracuda] #987203
05/07/11 12:42 AM
05/07/11 12:42 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
I too have also had good-luck with the OEM drums ... but I have never broken a sprag. And to be perfectly honest ...I potentially have a WORSEer problem than 99.9% of the others ... I drilled the band surface THROUGH TO THE CLUTCHES (like a vented rotor) as an experiment way back when. If my sprag failed ...I am sure that my drum would come-apart sooner(lower RPM) than a stocker.
And the more I think about all this ... the more I am thinking about changing THAT DRUM before I see any other drag-strip or street action. It is a 65 trans in my 62 ..and that stuff is getting harder to find now..... ESPECIALLY that 65 Race Hemi converter.
THAT THING has been a sweetheart. SOMETHING about that converter has me keeping putting that back in the car for years ...even though I had a good Fairbanks WD deal ...way-back-when ....
Re: Burnouts,exploding trannys and lauch proceedure [Re: shoebox] #987204
05/07/11 01:01 AM
05/07/11 01:01 AM
Az
Crizila Offline
Crizila  Offline
Az
How you do your burn out will depend on how your trans is set up. I run a 727 with a 4 clutch steel front drum and a Turbo-Action Cheetah Pro street valve body - has low band apply and will upshift automatically in drive. I pull in to the water in drive ( 1st gear ). With the line lock on, I dip in to the throttle and let the trans upshift in to 3rd. I then release the line lock and feed in more throttle as the car powers out of the water - sometimes referred to as a "power burn out". As the tires get traction and the motor starts to lug down, I ease out of the throttle around 20 feet in front of the staging lights. As I come to a stop, I dump it in neutral, give it a blip or two to make sure the motor is clean and the secondary squirters are fuel charged, and I am ready to go. Again, this is just my proceedure.
http://s79.photobucket.com/albums/j160/jcailey/?action=view&current=MOV01123.mp4
Fastest 300
Re: Burnouts,exploding trannys and lauch proceedure [Re: Crizila] #987205
05/07/11 01:17 AM
05/07/11 01:17 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Re: Burnouts,exploding trannys and lauch proceedure [Re: cbarracuda] #987206
05/07/11 09:59 AM
05/07/11 09:59 AM
CrazyD Offline
CrazyD  Offline
If it was a MANUAL valve body 727, burnout should start in what gear?
Re: Burnouts,exploding trannys and lauch proceedure [Re: CrazyD] #987207
05/07/11 10:19 AM
05/07/11 10:19 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
2nd gear
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: Burnouts,exploding trannys and lauch proceedure [Re: CrazyD] #987208
05/07/11 10:29 AM
05/07/11 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
2nd or high gear... if you have a light car or plenty
of power just start in high... your trying to get
heat into them and the faster tire RPM does it quicker
Page 1 of 3 1 2 3
