Re: indy heads one darker in color than the other???
[Re: fourgearsavoy]
#986962
05/06/11 12:09 AM
05/06/11 12:09 AM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have worked in diecast at briggs stratton for 8 years 2 things make alum change colors (cast anyway) 1 is the alum was 2 differnt temps when poured ,die was cooler on the darker one 2 the darker head was wet with something the hoter the die and alum is when poured the shiner/ brighter the part is when it comes out a colder part has a greater chance to have prosity in it as the alum is trying to firm up
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: 440Jim]
#986966
05/06/11 01:48 PM
05/06/11 01:48 PM
Posts: 5,080 organ
maximum entropy
organ
unacceptable. they should be identical. processes and methods are refined enough (one would hope) that this would not happen. maybe it won't be an issue. maybe the bruins will win the stanley cup. maybe...
[Re: Lil Demon]
#986971
05/06/11 06:30 PM
05/06/11 06:30 PM
Quicktree
I'm going to respectfully disagee with most in this thread. You just paid Indy good money for those heads. Tell them the issue and have them send you a new head - period.
could lead to problems down the road and they are not the easiest to deal with. do it now.
[Re: rlm2268]
#986975
05/06/11 08:57 PM
05/06/11 08:57 PM
one head is darker, almost a gray color
Time for a paternity test...
<Maury Povich> "You are NOT the father!</Maury Povich>
#986976
05/06/11 09:01 PM
05/06/11 09:01 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Thats funny right there...
I agree with the above. You spend hard earned money on something they should make it right and do it right away. Indy will find a way to get out of it otheriwse...
Did you ever get in touch with Gritzmacher to do your heads?
[Re: Stanton]
#986978
05/06/11 09:10 PM
05/06/11 09:10 PM
Posts: 3,395 Pa
Hot 340
Pa
Indy will say its not an issue and will do nothing.
I got ten bucks thats says they'll hang up on you. lol.
[Re: Stanton]
#986979
05/06/11 09:12 PM
05/06/11 09:12 PM
Posts: 1,015 Down South
DaKuda
Down South
