indy heads one darker in color than the other??? #986960
05/05/11 09:31 PM
05/05/11 09:31 PM
Wis.
rlm2268 Offline OP
rlm2268  Offline OP
Wis.
I noticed when I took my indy SR cnc 295 heads out of the box one head is darker, almost a gray color and the other looks like regular aluminum color. Anyone ever see this and what causes it?, kinda sucks because I'm kinda picky on appearance.
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986961
05/05/11 10:13 PM
05/05/11 10:13 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
My EZ's have what looks like a stain in the casting and I tried 3 different things to clean it and it seems to be permanent
Gus
64 Plymouth Savoy
Dana 60
Re: indy heads one darker in color than the other??? [Re: fourgearsavoy] #986962
05/06/11 12:09 AM
05/06/11 12:09 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i have worked in diecast at briggs stratton for 8 years
2 things make alum change colors (cast anyway)
1 is the alum was 2 differnt temps when poured ,die was cooler on the darker one
2 the darker head was wet with something
the hoter the die and alum is when poured the shiner/ brighter the part is when it comes out
a colder part has a greater chance to have prosity in it as the alum is trying to firm up
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: indy heads one darker in color than the other??? [Re: toplescuda] #986963
05/06/11 10:21 AM
05/06/11 10:21 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
Ill take em if you just can't stand them....
Re: indy heads one darker in color than the other??? [Re: Joshs68] #986964
05/06/11 12:49 PM
05/06/11 12:49 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
383, Hemi 4-Speed, AlterKtion, D60
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986965
05/06/11 01:22 PM
05/06/11 01:22 PM
NC
440Jim Offline
440Jim  Offline
NC
Have you tried taking a wire wheel on a drill to shine 'em up?
Re: indy heads one darker in color than the other??? [Re: 440Jim] #986966
05/06/11 01:48 PM
05/06/11 01:48 PM
organ
maximum entropy Offline
organ
unacceptable. they should be identical. processes and methods are refined enough (one would hope) that this would not happen. maybe it won't be an issue. maybe the bruins will win the stanley cup. maybe...
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986967
05/06/11 03:16 PM
05/06/11 03:16 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
you are going to like those 295 sr,s. i have 3 sets....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: indy heads one darker in color than the other??? [Re: Old School] #986968
05/06/11 03:39 PM
05/06/11 03:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
You can use Eagle One Etching Mag Cleaner, or just cast aluminum cleaner. It will turn them both white in color. I always used this stuff on my aluminum heads/block.. and they always look near new after.... Just use brush and scrub them soaked in this stuff.
Re: indy heads one darker in color than the other??? [Re: Joshs68] #986969
05/06/11 05:15 PM
05/06/11 05:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Just paint the damn things with aluminum cast-blast and forget it.
I'm as picky as you are and had no two cast pieces the same color in the the entire engine compartment - until I painted them all !!!
Re: indy heads one darker in color than the other??? [Re: Stanton] #986970
05/06/11 06:26 PM
05/06/11 06:26 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
I'm going to respectfully disagee with most in this thread. You just paid Indy good money for those heads. Tell them the issue and have them send you a new head - period.
Re: indy heads one darker in color than the other??? [Re: Lil Demon] #986971
05/06/11 06:30 PM
05/06/11 06:30 PM
Q
Quicktree Offline
Quicktree  Offline
Q
could lead to problems down the road and they are not the easiest to deal with. do it now.
Re: indy heads one darker in color than the other??? [Re: Lil Demon] #986972
05/06/11 06:40 PM
05/06/11 06:40 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i agree with lil demon. we work hard for our money. companies talk up their product, get ur cash, then u receive their product & it's not up to the standards u think they should be. i'm picky too, i'd send them back. u could try some zepalume, it's a good aluminum brightner. seeya.
Re: indy heads one darker in color than the other??? [Re: rickraw] #986973
05/06/11 07:18 PM
05/06/11 07:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Lets see some pics....
Re: indy heads one darker in color than the other??? [Re: Bob_Coomer] #986974
05/06/11 08:50 PM
05/06/11 08:50 PM
FastOne Offline
FastOne  Offline
I noticed a bit of core shift in one Indy head so thought I'd weigh the pair out of curiosity, the core shift head was lighter than the other one
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986975
05/06/11 08:57 PM
05/06/11 08:57 PM
Time for a paternity test...
<Maury Povich> "You are NOT the father!</Maury Povich>
Re: indy heads one darker in color than the other??? #986976
05/06/11 09:01 PM
05/06/11 09:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Thats funny right there...
I agree with the above. You spend hard earned money on something they should make it right and do it right away. Indy will find a way to get out of it otheriwse...
Did you ever get in touch with Gritzmacher to do your heads?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: indy heads one darker in color than the other??? [Re: rlm2268] #986977
05/06/11 09:06 PM
05/06/11 09:06 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Indy will say its not an issue and will do nothing.
Re: indy heads one darker in color than the other??? [Re: Stanton] #986978
05/06/11 09:10 PM
05/06/11 09:10 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I got ten bucks thats says they'll hang up on you. lol.
Re: indy heads one darker in color than the other??? [Re: Stanton] #986979
05/06/11 09:12 PM
05/06/11 09:12 PM
Down South
DaKuda Offline
DaKuda  Offline
Down South
