Re: Sequence Patterns and Codes
[Re: M_code_Coop]
#9859
07/02/04 12:02 PM
07/02/04 12:02 PM
coop; Sorry to say I don't wish to disply my vin number or fender tag(in a open forum) If the information is that important to your quest I would send it to you in a PM. I know you would only use it for the right perpose. I will give you most of the vin (WM23M9A2688XX) if this is anything more than just another one in sequence I could give you more info as I said. Good luck with your quest. Ed
[Re: M_code_Coop]
#9861
07/04/04 11:09 AM
07/04/04 11:09 AM
Posts: 5,160 Texas
dannysbee
Texas
Coop Mine is 290229 trans 2854 May 21,1969.
Getting old just means you were smarter than some and luckier than others.
[Re: M_code_Coop]
#9863
08/26/04 06:16 PM
08/26/04 06:16 PM
Hi does any know excactly how many A12 Road Runners were built in 69 ?
[Re: M_code_Coop]
#9865
10/03/04 08:05 PM
10/03/04 08:05 PM
First time here,
RM23M9A282561 01446 282058 9A282561 + 925 999 603 26 A12
K2 K2 M6X X9 E63 D21 RM23 426 949619
It's under restoration, coming along real nice.
[Re: MI_Custumz]
#9868
11/12/04 10:33 AM
11/12/04 10:33 AM
Posts: 1,678 N.C.
Nekid_A12
N.C.
Here's a car off ebay. It's VIN is RM23H9A297104 and built on 616. It's VIN is after #26 on the registry of WM23MA297967 with build date of 426. Hope that will help some.
Uuumm...297104 is BEFORE 297967, not after. And I'm not sure it means anything since one is an "RM" and the other is a "WM"
Thoughts??
If at first you don't succeed, try a bigger hammer. Have Large Wooden Spoon...will stir pots <img src="/ubbthreads/images/graemlins/stirthepot.gif" alt="" />, making friends wherever I go Well....it's supposed to Car #216 http://regcars.homestead.com/car216.html
[Re: MI_Custumz]
#9870
11/12/04 12:42 PM
11/12/04 12:42 PM
Posts: 21,547 N.E. OHIO, USA
A12
N.E. OHIO, USA
Was the last date of production in June or July for a model year. (I know I should go back and read again but I'm feeling pretty lazy today )
[Re: MI_Custumz]
#9872
11/12/04 03:02 PM
11/12/04 03:02 PM
Posts: 1,678 N.C.
Nekid_A12
N.C.
Late night. You're right, the one on bay is earlier than the one on the registry. I thought the sequence # was for that plant, so a WM could be let's say #123456 and a RM could be #123457 and don't forget the GTX, Belvedere, and Coronets built at Lynch Rd. Just shows that all A12's were not built on just 329 and 426.
Understood And a good thought. I'd like to see some other RM21X9A SPD's myself to help narrow down the date of my car. As it stands, I believe it was probably the second week of May 69. But I'm not totally sure.
[Re: MI_Custumz]
#9875
12/23/04 11:55 PM
12/23/04 11:55 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Here is a car that was just on Ebay, good to help date 3/29 cars
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#9876
12/24/04 01:39 PM
12/24/04 01:39 PM
AZ_A12_BEE
Dreaming of the 808
And here is one for the 4/26 cars, my car 263554 was actually built on 4/29 using the dealer invoice date and this car is about 125 ahead of my car and is 4/28
37 Plymouth PU
[Re: AZ_A12_BEE]
#9877
12/31/04 09:50 PM
12/31/04 09:50 PM
AZ_A12_BEE
Dreaming of the 808
They dont get much later than this
37 Plymouth PU
