Page 4 of 7 1 2 3 4 5 6 7
Re: Sequence Patterns and Codes [Re: M_code_Coop] #9859
07/02/04 12:02 PM
07/02/04 12:02 PM
coop;
Sorry to say I don't wish to disply my vin number or fender tag(in a open forum) If the information is that important to your quest I would send it to you in a PM. I know you would only use it for the right perpose. I will give you most of the vin (WM23M9A2688XX) if this is anything more than just another one in sequence I could give you more info as I said. Good luck with your quest. Ed
Re: Sequence Patterns and Codes #9860
07/04/04 08:10 AM
07/04/04 08:10 AM
Harleysville PA
M_code_Coop Offline OP
Harleysville PA
Here's a trans case found in Texas with a VIN of 9A297974. Dated '2861' which is May 28 1969. (see attached)
Looks like a factory paint stamp of '605' on the case.
996708-trans case.jpg (345 downloads)
Link to Slideshow...turn the music up. http://albums.phanfare.com/isolated/F39VvCq5/1/1491997 ...So when does government's A12 welfare start?..
Re: Sequence Patterns and Codes [Re: M_code_Coop] #9861
07/04/04 11:09 AM
07/04/04 11:09 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Coop
Mine is 290229 trans 2854 May 21,1969.
Getting old just means you were smarter than some and luckier than others.
Re: Sequence Patterns and Codes [Re: dannysbee] #9862
07/05/04 01:59 PM
07/05/04 01:59 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
There's one on e-bay
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=2483798012&category=43921
19113 307134 9A305078
925 594 603
26
1X 7X N96
F5 F5 H2G F8 V21
RM23 E63 D21 701 188986
That's the tag info posted. It falls in between some WM23 cars on the registry. No pic of tag, so there's another one to help when the cars were built.
998835-sig pic1.JPG (257 downloads)
Re: Sequence Patterns and Codes [Re: M_code_Coop] #9863
08/26/04 06:16 PM
08/26/04 06:16 PM
Hi does any know excactly how many A12 Road Runners were built in 69 ?
Re: Sequence Patterns and Codes #9864
08/26/04 06:20 PM
08/26/04 06:20 PM
Harleysville PA
Harleysville PA
check this page near the bottom:
http://www.homestead.com/sixpacksixbbl/
Regards,
Coop
Re: Sequence Patterns and Codes [Re: M_code_Coop] #9865
10/03/04 08:05 PM
10/03/04 08:05 PM
First time here,
RM23M9A282561
01446 282058 9A282561
+ 925 999 603
26 A12
K2 K2 M6X X9
E63 D21 RM23 426 949619
It's under restoration, coming along real nice.
Re: Sequence Patterns and Codes [Re: M_code_Coop] #9866
10/23/04 11:46 PM
10/23/04 11:46 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Here are the date codes and other numbers off of my Road Runner. It is in a Microsoft Word document.
Re: Sequence Patterns and Codes [Re: Dave Watt] #9867
11/11/04 01:34 PM
11/11/04 01:34 PM
MI_Custumz Offline
MI_Custumz  Offline
Here's a car off ebay. It's VIN is RM23H9A297104 and built on 616. It's VIN is after #26 on the registry of WM23MA297967 with build date of 426. Hope that will help some.
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9868
11/12/04 10:33 AM
11/12/04 10:33 AM
N.C.
Nekid_A12 Offline
Nekid_A12  Offline
N.C.
Uuumm...297104 is BEFORE 297967, not after. And I'm not sure it means anything since one is an "RM" and the other is a "WM"
Thoughts??
If at first you don't succeed, try a bigger hammer.
Have Large Wooden Spoon...will stir pots <img src="/ubbthreads/images/graemlins/stirthepot.gif" alt="" />,
making friends wherever I go
Well....it's supposed to
Car #216
http://regcars.homestead.com/car216.html
Re: Sequence Patterns and Codes [Re: Nekid_A12] #9869
11/12/04 12:25 PM
11/12/04 12:25 PM
MI_Custumz Offline
MI_Custumz  Offline
Late night. You're right, the one on bay is earlier than the one on the registry. I thought the sequence # was for that plant, so a WM could be let's say #123456 and a RM could be #123457 and don't forget the GTX, Belvedere, and Coronets built at Lynch Rd. Just shows that all A12's were not built on just 329 and 426.
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9870
11/12/04 12:42 PM
11/12/04 12:42 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Was the last date of production in June or July for a model year.
(I know I should go back and read again but I'm feeling pretty lazy today )
Re: Sequence Patterns and Codes #9871
11/12/04 01:10 PM
11/12/04 01:10 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
First time here,
RM23M9A282561
+ 925 999 603
26 A12
K2 K2 M6X X9
Tailbutcher,
Welcome to the Forum
Have you checked out plans for the A12 Reunion next July?? Hope to see you there even if your RR is not done.
One requirement is PHOTOS! Post what you can for us.
Frank
dstryr, since 1986.
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9872
11/12/04 03:02 PM
11/12/04 03:02 PM
N.C.
Nekid_A12 Offline
Nekid_A12  Offline
N.C.
Understood And a good thought. I'd like to see some other RM21X9A SPD's myself to help narrow down the date of my car. As it stands, I believe it was probably the second week of May 69. But I'm not totally sure.
Car #216
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9873
11/12/04 03:12 PM
11/12/04 03:12 PM
MI_Custumz Offline
MI_Custumz  Offline
I looked at a Runner from Lynch Rd. a while back and here is what it had on the tag:
last 6-267355
scheduled build date-506
order number-145026
Hope this helps some. It was a 383 car.
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9874
12/13/04 11:56 AM
12/13/04 11:56 AM
MI_Custumz Offline
MI_Custumz  Offline
Found 2 Lynch Rd Runners on Ebay.
Link to first one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4511261434&category=43921
Title shows last 6 of 256589 and registration shows 216589. No fender tag shown. Supposedly owned by Jesse James, maybe someone can call on the build date?
Link to second one:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4511439829&category=43921
RM21H9A254049
01162 254955 9A254049
925 595 603 N96(Air Grabber Hood)
B5 B5(Blue Fire Metalic) H2X( Black interior) X9(Black velvet accent colours)
RM21(2 dr Coupe) E63(383/4bbl/335hp) D21(Heavy Duty 4 speed)
404(April/ 04/ 69) B 28914(Production Sequence)
Hope that helps some of the build date mysteries.
Re: Sequence Patterns and Codes [Re: MI_Custumz] #9875
12/23/04 11:55 PM
12/23/04 11:55 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Here is a car that was just on Ebay, good to help date 3/29 cars
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Sequence Patterns and Codes [Re: AZ_A12_BEE] #9876
12/24/04 01:39 PM
12/24/04 01:39 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
And here is one for the 4/26 cars, my car 263554 was actually built on 4/29 using the dealer invoice date and this car is about 125 ahead of my car and is 4/28
Re: Sequence Patterns and Codes [Re: AZ_A12_BEE] #9877
12/31/04 09:50 PM
12/31/04 09:50 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
They dont get much later than this
Re: Sequence Patterns and Codes [Re: AZ_A12_BEE] #9878
01/15/05 10:09 PM
01/15/05 10:09 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
I was looking at a A12 Bee today.
WM23M9A306xxx
Matching numbers engine cast 5/23, engine assembled 6/18.
