Re: biggest 340 cam and still have power brakes?
[Re: rave_12000]
#985292
05/03/11 11:31 AM
05/03/11 11:31 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
no matter how big the cam, when you lift on the throttle and the engine is still spinning 1500-2000 rpm, it will "charge" the vacuum booster, and you'll get one or 2 pumps of the brakes. stop and go traffic is different obviously...
but, you could get a vacuum canister to store up extra vacuum, get an electric vacuum pump dedicated to the brake booster and hidden under the fender out of sight, or go with manual brakes.
**Photobucket sucks**
