biggest 340 cam and still have power brakes? #985285
05/03/11 12:50 AM
05/03/11 12:50 AM
kansas city, mo
rave_12000 Offline OP
kansas city, mo
wondering how big of cam I can put in a 340 in my 70 challenger and still have power brakes???? Comp cams.
Re: biggest 340 cam and still have power brakes? [Re: rave_12000] #985286
05/03/11 12:53 AM
05/03/11 12:53 AM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
I say RUN whatever you want ...NO WORRY ... just get a vacuum-storage-cannister
Re: biggest 340 cam and still have power brakes? [Re: dOc …] #985287
05/03/11 08:31 AM
05/03/11 08:31 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Re: biggest 340 cam and still have power brakes? [Re: rave_12000] #985288
05/03/11 08:53 AM
05/03/11 08:53 AM
Mid Michigan
Coronet-R/T-Rag Offline
Mid Michigan
I've run the canister with my 340 and you get about 2 pumps at idle then no more vacuum. I would stay under 240 degrees of duration at 50. Actually, I would put on manual brakes and not worry about it.
Re: biggest 340 cam and still have power brakes? [Re: Coronet-R/T-Rag] #985289
05/03/11 09:15 AM
05/03/11 09:15 AM
IN
ahy Offline
ahy  Offline
IN
I'd guess 220 deg @.050 would work and 230 a big maybe depending on compression, lobe seperation and other details. PB seem to work OK with 12-13" or more vacuum.
Tuneup also has a big impact on vacuum. Bigger cams like plenty of idle advance and careful mixture adjustment.
Re: biggest 340 cam and still have power brakes? [Re: ahy] #985290
05/03/11 11:13 AM
05/03/11 11:13 AM
Outside
thedriver Offline
thedriver  Offline
Outside
i use a XE285HL comp hydraulic on my 340. my car operates generally in 4000ft-6500ft DA. Power brakes still work, but tuneup is definitely part of it.
1973 challenger
Dana. 4 speed. Low deck.
Re: biggest 340 cam and still have power brakes? [Re: thedriver] #985291
05/03/11 11:26 AM
05/03/11 11:26 AM
kansas city, mo
kansas city, mo
had 268/280 224/230 .477/.480....thinkin about bumpin up to 274/286 230/236 .480/.491. comp cams. any advantage here? 340 six pak approx 9.5 to 1 compression.
Re: biggest 340 cam and still have power brakes? [Re: rave_12000] #985292
05/03/11 11:31 AM
05/03/11 11:31 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
no matter how big the cam, when you lift on the throttle and the engine is still spinning 1500-2000 rpm, it will "charge" the vacuum booster, and you'll get one or 2 pumps of the brakes. stop and go traffic is different obviously...
but, you could get a vacuum canister to store up extra vacuum, get an electric vacuum pump dedicated to the brake booster and hidden under the fender out of sight, or go with manual brakes.
**Photobucket sucks**
Re: biggest 340 cam and still have power brakes? [Re: rave_12000] #985293
05/03/11 01:19 PM
05/03/11 01:19 PM
Outside
thedriver Offline
thedriver  Offline
Outside
you would notice a slight hp increase with that cam. However, i doubt it would be worth the money (and labour)for the increase in power over the 268. like maybe 15hp?? i would recommend spending the money on something else.
I used to run the comp 268 cam in my 340, i had iron heads, 10:1cr headers etc. I decided on the cam change (285HL, like i previously mentioned) but also went with edelbrock heads. power increase was substantial. but looking back, it was probably mostly due to the heads.
1973 challenger
