69 GTX fender tag decode #985179
05/02/11 11:09 PM
05/02/11 11:09 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I am no expert on Lynch Road fender tags, so youse in the know please help me out! This is what I know now:
69 GTX
NOM 1972 440
console 4-speed
Dana 3.54
What looks like is used to have an air grabber
97 Rallye green repainted to F8
F8 vinyl bucket interior
055 radiator w/fan shroud
Manual steering and manual drum brakes
Scattershield and aftermarket engine parts
No lower trim on above the rockers, was this on all 69 GTX's?
14" Magnum wheels
JB Rhinehart, Realist
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985180
05/02/11 11:13 PM
05/02/11 11:13 PM
Orleans, Ontario
moparcanuk Offline
moparcanuk  Offline
Orleans, Ontario
All 69 GTXs had the chrome trim above the rocker panels.
Re: 69 GTX fender tag decode [Re: moparcanuk] #985181
05/02/11 11:18 PM
05/02/11 11:18 PM
Rhinotruck
Rhinotruck
So the trim must have been removed during the repaint, not good!
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985182
05/03/11 12:01 AM
05/03/11 12:01 AM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
69 GTX
NOM 1972 440
console 4-speed
Dana 3.54
14" Magnum wheels
OK, my best go at it;
03149 and 272142 = gate and line sequence numbers
9 = 1969
A = Lynch Rd. assy. plant
262919 = sequential VIN #
915 = 440 4bbl auto trans, orange
596 3.54 Dana 60 11" drums F and R, A33 pkg
605 = 833 4spd 18 spline
26 = 26" rad
1X - Black vinyl roof
68 = ??
N96 = fresh air hood
C16 = console
97 = bright green met. special order
97 = upper door color as above
P6C = premium buckets
F8 = interior color - dark green
V21 = performance hood treatment
RS = GTX
23 = 2dr hrdtp
E86 = 440, 4bbl htr.
D21 = 4spd
423 = april 23rd 1969 SPD
235801 = VON vehicle order number.
.....ok, how'd I do?
neat car, btw.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 69 GTX fender tag decode [Re: DPelletier] #985183
05/03/11 12:44 AM
05/03/11 12:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
69 GTX
NOM 1972 440
console 4-speed
Dana 3.54
14" Magnum wheels
9 = 1969
26 = 26" rad
68 = ??
C16 = console
RS = GTX
23 = 2dr hrdtp
D21 = 4spd
neat car, btw.
you did pretty good except
03149 is Gate and sequence number
262142 is the body number ... something like that , this number is NO WHERE but on the lynch rd. tag , not on broadcast sheet or any other piece of paper I have seen.
68 is V68 , Lynch Rd. left off the V, sport stripe, longitudinal tape ... DELETED .
Re: 69 GTX fender tag decode [Re: JohnRR] #985184
05/03/11 02:23 AM
05/03/11 02:23 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
03= gate
149 = base number
262919 = sequence number or basically the way John described it.
69 LR coded C16 for both the console and the buddy seat so just seeing this code on the tag really doen't tell you which it recieved.
paint code 97 GTX= VERY uncommon.
97 and 97 paint code = roof and body were Rallye Green
P6C = blue and white interior. The code is actually P6G for green interior to go with the exterior. (The tail is missing from the G. Compare the G to the C in C16) F8 = UDF color
Yes. nice car
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 GTX fender tag decode [Re: 69CoronetRT] #985185
05/03/11 11:09 AM
05/03/11 11:09 AM
Rhinotruck
Rhinotruck
03= gate
149 = base number
Yes. nice car
So the roof was painted 97 but a black vinyl top put over it? Also, the V68 longintudinal stripe delete would be the stripe following the missing rocker trim? Is there anyway to tell if the car had the trim deleted without attacking the paint? Anyone ever see a 69 GTX without the trim from the factory? I am not up on these cars, I only know Darts, so any info would be appreciated!
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985186
05/03/11 11:14 AM
05/03/11 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Vinyl roof or not the code is there on the tag for the upper body paint in 1969. I don't know if it was possible to delete the lower body black out on the 69 GTX ?
Since the car has been repainted does it matter if the original paint was disturbed ?
Re: 69 GTX fender tag decode [Re: Rhinodart] #985187
05/03/11 12:21 PM
05/03/11 12:21 PM
DPelletier Offline
DPelletier  Offline
03= gate
149 = base number
Yes. nice car
I should have known the 68 was V68!! seems I could remember that 1X was V1X but not that 68 was V68........I have no excuse! Oh well, I am getting better!
I would imagine that the 97 code paint is VERY rare.....I wonder if anyone has the '69 paint percentages for GTX's.
Re: 69 GTX fender tag decode [Re: DPelletier] #985188
05/03/11 12:25 PM
05/03/11 12:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
03= gate
149 = base number
Yes. nice car
You can argue with me if you like ... ..
Upper door color is F8 , it's the code after the P6G
Re: 69 GTX fender tag decode [Re: JohnRR] #985189
05/03/11 12:56 PM
05/03/11 12:56 PM
DPelletier Offline
DPelletier  Offline
No, I know better than that too!
I should stick with '70 tags...
Re: 69 GTX fender tag decode [Re: JohnRR] #985190
05/03/11 07:09 PM
05/03/11 07:09 PM
Rhinotruck
Rhinotruck
The F8 on the car looks good, I don't want to disturb the new paint to see if the holes were filled for the trim. Are any of the holes visible from the inside, like on the fender or door?
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985191
05/03/11 07:37 PM
05/03/11 07:37 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Should be. I just had to find two (one on each side) of the 23-25 holes (each side, about 50 total) that got filled in with body filler and that was easy for one because of the oooze of filler on the back side of the hole. Look inside of the trunk or remove the front inner fender seal where the antenna is (can see it from the door jam) or look/feel on top of the wheel openings where the wheel opening trim get screwed in place. If you look closely at the right rear quarter panel here you will see that one of the five trim holes is not there. The trim holes between the rear bumper and the right rear wheel opening are equal distances apart and you can see where one should be. I went into the trunk and there was a small, very small dome of filler there and I took a very small drill bit and worked through it by hand and then increased the size (all by hand) until it was back to the original size.
With about 46 original holes for the GTX trim (not including the approximately 16 wheel opening trim holes) I'm betting you can find at least one....maybe two if they were there in the first place.
MikeR
Note #3 hole (middle) is missing but you can see the placement from inside the trunk, at least I could on my car
Re: 69 GTX fender tag decode [Re: A12] #985192
05/03/11 08:31 PM
05/03/11 08:31 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
If this turns out to be a "GTX TRIM DELETE" car then I won't know whether to be shocked, excited or what...........because my A12 Road Runner has GTX trim and photos going back to the very early '70's with the GTX trim on it (March '71 photos) and I went and measured the exact size and location of each one of the holes on the GTX and compared them to the A12 Road Runner and they are in the exact same place, which kind of may mean that no dealer or owner could have been that precise to get all of the trim holes in the same production location and the RR holes do not have holes that appear to be done by a drill bit with the inside flare on the hole edge.....you may have a "GTX trim delete" and I may have "GTX trim add" car. My A12 car of course is a Lynch Road car like your GTX and we're about 1000 cars apart. Your car is a 4/23 SPD and of course the second build date for the A12's was 4/26
Back to your GTX......some day you should take it back to 97 Ralley Green that's as rare as a Y4 Spanish Gold A12 Road Runner.....WITH GTX trim IMO another co-inky-dink (rare colors too)
MikeR
Re: 69 GTX fender tag decode [Re: A12] #985193
05/04/11 12:01 AM
05/04/11 12:01 AM
Rhinotruck
Rhinotruck
Thanks for all the replies. Maybe the car I am looking at was supposed to be an A12 and yours a GTX?
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985194
05/04/11 12:57 AM
05/04/11 12:57 AM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
James would you do a favor for me and check to see if my broadcast sheet is in your car.......I'll check the RR for your sheet in the mean time
Be interesting to know the date code on the K-frame, my K-frame date code is 120 9 (April 30, 1969)
MikeR
Re: 69 GTX fender tag decode [Re: A12] #985195
05/04/11 12:13 PM
05/04/11 12:13 PM
DPelletier Offline
DPelletier  Offline
This may be the first time I've heard of someone color changing a car TO F8!
Re: 69 GTX fender tag decode [Re: A12] #985196
05/04/11 07:18 PM
05/04/11 07:18 PM
Rhinotruck
Rhinotruck
MikeR
It is not my car, I inspected it for a client who is looking to buy a 69 GTX. I am waiting to here if he wants it or not, but I do plan on going back and checking it out further. He said that there was no broadcast sheet found when the seats were out for the new carpet, but no other place they can be found at has been checked yet.
A-Body's RULE!
Re: 69 GTX fender tag decode [Re: Rhinodart] #985197
05/04/11 09:16 PM
05/04/11 09:16 PM
69x Offline
69x  Offline
Rallye green Is very rare on a 69 GTX, I have never seen one before
Strange that someone painted it F8 green
Re: 69 GTX fender tag decode [Re: 69x] #985198
05/04/11 09:53 PM
05/04/11 09:53 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Even stranger that someone painted it GREEN as DaveP mentioned........nobody likes GREEN MOPARS....
MikeR
Before you flame me, I'm kidding!; go back through my history...I LOVE GREEN MOPARS!
