#98510 - 08/02/08 10:00 AM front suspension ride hight
A47 Offline
Loc: under the hood
hi guys ..need info on the stock ride hight of a 69 charger 440 R/T ..
any pictures where to measure it ... appreciate anyhelp guys
#98511 - 08/02/08 10:17 AM Re: front suspension ride hight [Re: A47]
375inStroke Offline
Special needs person
Loc: Seattle, WA
From the FSM: Measure distance from lowest point of one adjusting blade to floor and from lowest point of steering knuckle arm to floor. The difference is 1-7/8" 1/8"
The picture shows them measuring on the inside of the control arm on the round part of the adjuster blade, and the bottom of the ball joint that they call the knuckle. The ball joint is lower than the adjuster.
#98512 - 08/02/08 10:24 AM Re: front suspension ride hight [Re: 375inStroke]
A47 Offline
Loc: under the hood
thanks for the quick reply Dude
can't find that section in my FSM ... may be some pages are missing don't say anywhere ride hight ....... ????
#98513 - 08/02/08 05:27 PM Re: front suspension ride hight [Re: A47]
TC@HP2 Offline
Loc: Pikes Peak Country
Looks like this. However, be warned that you may not like the ride height after it is set to factory specs. Too high in the nose, IMO.
#98514 - 08/03/08 11:12 AM Re: front suspension ride hight [Re: TC@HP2]
A47 Offline
Loc: under the hood
thanks for the picture appreciated ..i see too high ..just going to have a look see
25,492 Registered Members
193,090 Topics
1969 Plymouth Road Runner
by tomsjack
09/24/18 03:37 AM
what app uses a 5/16 (.312") 2.02 intake valve
by RapidRobert
09/24/18 01:04 AM
"central tool" micrometers: good/average quality?
by RapidRobert
09/24/18 01:00 AM
73 Charger project
by Neil
09/23/18 10:59 PM
