front suspension ride hight #98510
08/02/08 12:00 PM
08/02/08 12:00 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
hi guys ..need info on the stock ride hight of a 69 charger 440 R/T ..
any pictures where to measure it ... appreciate anyhelp guys
Re: front suspension ride hight [Re: A47] #98511
08/02/08 12:17 PM
08/02/08 12:17 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
From the FSM: Measure distance from lowest point of one adjusting blade to floor and from lowest point of steering knuckle arm to floor. The difference is 1-7/8" ±1/8"
The picture shows them measuring on the inside of the control arm on the round part of the adjuster blade, and the bottom of the ball joint that they call the knuckle. The ball joint is lower than the adjuster.
Re: front suspension ride hight [Re: 375inStroke] #98512
08/02/08 12:24 PM
08/02/08 12:24 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks for the quick reply Dude
can't find that section in my FSM ... may be some pages are missing don't say anywhere ride hight ....... ????
Re: front suspension ride hight [Re: A47] #98513
08/02/08 07:27 PM
08/02/08 07:27 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Looks like this. However, be warned that you may not like the ride height after it is set to factory specs. Too high in the nose, IMO.
Re: front suspension ride hight [Re: TC@HP2] #98514
08/03/08 01:12 PM
08/03/08 01:12 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks for the picture appreciated ..i see too high ..just going to have a look see
