What engine is in a 59 Fury #984864
05/02/11 01:55 PM
05/02/11 01:55 PM
SC
V194 Offline OP
V194  Offline OP
SC
At a local repair shop they had a 59 Fury convertible on the lift getting break work. I could only see the underside of a super original car and was wondering what might be powering it.
The engine is red with factory dual exhaust and is big block at least it has the oil filter in the front of the block. The transmission also looked unusual to me. It has a small fluid pan that is square. Any ideas on the engine and trans based on this?
Re: What engine is in a 59 Fury [Re: V194] #984865
05/02/11 02:03 PM
05/02/11 02:03 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Probably a 361 Golden Commando
Re: What engine is in a 59 Fury [Re: 1_WILD_RT] #984866
05/02/11 02:17 PM
05/02/11 02:17 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Three engines,225,318 and 361.
Re: What engine is in a 59 Fury [Re: 62maxwgn] #984867
05/02/11 02:18 PM
05/02/11 02:18 PM
SC
V194 Offline OP
V194  Offline OP
SC
Its a BB with the oil filter in the front of the engine so I guess thats 361
Re: What engine is in a 59 Fury [Re: 62maxwgn] #984868
05/02/11 02:41 PM
05/02/11 02:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Being a higher-end model, the Fury was only available with V-8 power.
Re: What engine is in a 59 Fury [Re: John_Kunkel] #984869
05/02/11 05:19 PM
05/02/11 05:19 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I believe they could have came with the odd-ball 383rb engine as well.
Re: What engine is in a 59 Fury [Re: pinkduster] #984870
05/03/11 02:00 AM
05/03/11 02:00 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
As stated above - Fury & Sport Fury were V8 only. & the /6 wasn't out yet.
Plymouth for '59:
230 cu.in. in-line 6 - 132hp
318 cu.in. 2bbl poly 8 - 230hp (STD in Fury)
318 cu.in. 4bbl poly 8 - 260hp (STD in Sport Fury)
361 cu.in. 4bbl "B-engine" 8 - 305hp
383 "RB-engine" was Chrysler ONLY
Re: What engine is in a 59 Fury [Re: 6bblgt] #984871
05/03/11 02:09 AM
05/03/11 02:09 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Re: What engine is in a 59 Fury [Re: 6bblgt] #984872
05/03/11 02:10 AM
05/03/11 02:10 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And since it was mentioned in the first post that the car has a big block.... 361 Golden Commando...
Re: What engine is in a 59 Fury [Re: 1_WILD_RT] #984873
05/03/11 08:13 AM
05/03/11 08:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
In the late 60s I bought a 59 Fury.It was an odd ball.Had a 350 3 speed manual with non power.Had to be a real early build.I did check the stamping on the block more than once.A friend bought it and the 47 Ford coupe I had for a build.Rocky
Chrysler Firepower
Re: What engine is in a 59 Fury [Re: therocks] #984874
05/03/11 09:03 AM
05/03/11 09:03 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
It probably is a 361, looks like a LB 383. If it has the 440 "step" accross from the dist. it is a RB 383. Although that motor was a higher end for Dodge and Desoto. The 350 was a 1958 motor, but it could of lasted into the early model year of 59. Chry. was trying to find its way once the HEMIs were dropped and all the changes that all the motor companies were fighting over with a downturn in the economy in 58 (recession).
My vote, site unseen, is that it's a 361
Re: What engine is in a 59 Fury [Re: DANA60] #984875
05/03/11 11:15 AM
05/03/11 11:15 AM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
Odd-ball RB 383 was only available in the '59 Chrysler Saratoga and Windsor, so I doubt that's what's in the Fury.
Re: What engine is in a 59 Fury [Re: Scottmon] #984876
05/04/11 12:02 AM
05/04/11 12:02 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Was the 383RB available in the Chrysler 300 in the early 60's? Guy I know just bought an early 60's 300 ans swears it has a 383 in it. When did the low block 383 debut?
Re: What engine is in a 59 Fury [Re: Ramrod39] #984877
05/04/11 07:22 AM
05/04/11 07:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
A 383 was available in a 62' and up 300 Sports Series. (low deck motor)Dave
