How much axle twist with caltracs? Welding new perches.
#984262
05/01/11 09:36 PM
05/01/11 09:36 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
Does anyone know about how many degrees the axle twists upwards with caltracs? I'm finishing up the dana and it's time to weld on the perches. My trans is 2 degrees down so I know where I'm at there. My driveshaft is 44" so I can get the driveshaft angle easy enough. I just want to try to work in some of the axle twist to set my perches right.
Chris from New Jersey
Re: How much axle twist with caltracs? Welding new perches.
[Re: j.mcconnell]
#984264
05/01/11 10:24 PM
05/01/11 10:24 PM
fig426
East Coast, NJ
Thanks. I also need to add that the springs are moved in about 4 inches, and my front spring eye is about 1 inch lower than the factory mount, which makes the leaf spring angle more from the rear to the front than a factory mounted spring. This is one of the reasons I'm looking for about how many degrees of twist I should expect.
[Re: fig426]
#984266
05/01/11 11:32 PM
05/01/11 11:32 PM
Posts: 7,506 Az
Crizila
Az
If you haven't purchased spring perches yet, you might want to look at what Calvert is selling. Best spring perches I've seen.
Fastest 300
[Re: Crizila]
#984267
05/02/11 08:33 AM
05/02/11 08:33 AM
fig426
East Coast, NJ
I have the perches and it's already mocked up and ready to be tacked. I just need to know how many degrees of twist to expect so I can work that into it.
[Re: fig426]
#984268
05/02/11 02:01 PM
05/02/11 02:01 PM
Posts: 256 S.W. Ohio
clyde
S.W. Ohio
[Re: moparniac]
#984270
05/02/11 03:02 PM
05/02/11 03:02 PM
Posts: 7,506 Az
Crizila
Az
make sure to box in the the perches!
Thats pretty much what I was referring to with the Calvert perches.
Fastest 300
