How much axle twist with caltracs? Welding new perches. #984262
05/01/11 09:36 PM
05/01/11 09:36 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Does anyone know about how many degrees the axle twists upwards with caltracs? I'm finishing up the dana and it's time to weld on the perches. My trans is 2 degrees down so I know where I'm at there. My driveshaft is 44" so I can get the driveshaft angle easy enough. I just want to try to work in some of the axle twist to set my perches right.
Chris from New Jersey
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984263
05/01/11 10:12 PM
05/01/11 10:12 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
-2 to -4 degree pinion angle. set your perches for 0 to -2
Re: How much axle twist with caltracs? Welding new perches. [Re: j.mcconnell] #984264
05/01/11 10:24 PM
05/01/11 10:24 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Thanks. I also need to add that the springs are moved in about 4 inches, and my front spring eye is about 1 inch lower than the factory mount, which makes the leaf spring angle more from the rear to the front than a factory mounted spring. This is one of the reasons I'm looking for about how many degrees of twist I should expect.
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984265
05/01/11 11:27 PM
05/01/11 11:27 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
I worried about how the spring angle played into pinion angle also so I mocked the housing up on the springs and tack welded the perches then removed it to weld it up.
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984266
05/01/11 11:32 PM
05/01/11 11:32 PM
Az
Crizila Offline
Crizila  Offline
Az
If you haven't purchased spring perches yet, you might want to look at what Calvert is selling. Best spring perches I've seen.
Fastest 300
Re: How much axle twist with caltracs? Welding new perches. [Re: Crizila] #984267
05/02/11 08:33 AM
05/02/11 08:33 AM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
I have the perches and it's already mocked up and ready to be tacked. I just need to know how many degrees of twist to expect so I can work that into it.
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984268
05/02/11 02:01 PM
05/02/11 02:01 PM
S.W. Ohio
clyde Offline
clyde  Offline
S.W. Ohio
Doin your own welding?
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984269
05/02/11 02:16 PM
05/02/11 02:16 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
make sure to box in the the perches! i am -2 at the tranny and -2 outback! is it ideal of the 60ft suspension world! I dunno thats just where I have it at for now..... good luck!
Mopar Performance
Re: How much axle twist with caltracs? Welding new perches. [Re: moparniac] #984270
05/02/11 03:02 PM
05/02/11 03:02 PM
Az
Crizila Offline
Crizila  Offline
Az
Thats pretty much what I was referring to with the Calvert perches.
Fastest 300
Re: How much axle twist with caltracs? Welding new perches. [Re: clyde] #984271
05/02/11 03:44 PM
05/02/11 03:44 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Always Randy!! Some of us Jersey boys are capable too. Granted, my welding equipment isn't as glamorous as yours, but it gets the job done.
Boxing in looks like a good plan also.
Re: How much axle twist with caltracs? Welding new perches. [Re: fig426] #984272
05/02/11 08:02 PM
05/02/11 08:02 PM
S.W. Ohio
clyde Offline
clyde  Offline
S.W. Ohio
Glamour is'nt what it's cracked up to be if ya don't know how to use it yet.
Re: How much axle twist with caltracs? Welding new perches. [Re: clyde] #984273
05/02/11 08:22 PM
05/02/11 08:22 PM
East Coast, NJ
fig426 Offline OP
fig426  Offline OP
East Coast, NJ
Yeah but it's still awesome equipment! If nothing else, it looks cool in the garage!
