max wedge pcv location? #984139
05/01/11 05:45 PM
05/01/11 05:45 PM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
Im running a 500 stroker with a M/W top end ,I have the pcv hose going into the base of the carb is this sufficiant or do I need to use the port on the manifold?.
Re: max wedge pcv location? [Re: moparsquid] #984140
05/01/11 08:06 PM
05/01/11 08:06 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The original MW PCV hose went directly to the manifold.
Re: max wedge pcv location? [Re: John_Kunkel] #984141
05/01/11 11:00 PM
05/01/11 11:00 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks, will it affect opperation if i leave it on the carb or shall i relocate it to the manifold.
Re: max wedge pcv location? [Re: moparsquid] #984142
05/01/11 11:39 PM
05/01/11 11:39 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Well, I know {if it were mine}I'd rather have it attached to the manifold...Having the two carbs in tune is tough enough without adding an oil/smoke belching hose to just one carb..
Re: max wedge pcv location? [Re: moparsquid] #984143
05/01/11 11:42 PM
05/01/11 11:42 PM
W a single plane intake/single carb I would think the controlled vac leak (PCV) would affect it (eng A/F ratio) the same no matter where it is introduced EDIT just saw the pic-2 carbs
Re: max wedge pcv location? [Re: screamindriver] #984144
05/02/11 01:13 AM
05/02/11 01:13 AM
Spring Valley ,Ca.
Spring Valley ,Ca.
THANKS Ill change it when i get a chance again thanks.
