trans cooler fitting size? #98403
08/02/08 01:45 AM
08/02/08 01:45 AM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
could anyone tell me off hang the size and degree of the fittings that go to the trans cooler on a 904 trans. I think it's a 37 degree right? I'm going to go to the hardware store and get some new ones mine are crimped and it's not letting my trans cool.
thanks a lot
-matt
if your dreaming of your car then it's your dream car....
Re: trans cooler fitting size? [Re: 64dartsb] #98404
08/02/08 04:13 AM
08/02/08 04:13 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The case is threaded 1/8"-27 NPT and the factory cooler lines are 5/16" flare. The angle of the flare is 45°, the 37° flare is used on AN fittings.
Re: trans cooler fitting size? [Re: John_Kunkel] #98405
08/02/08 06:58 AM
08/02/08 06:58 AM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
45* = hardware store
37* = an or jic
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: trans cooler fitting size? [Re: John_Kunkel] #98406
08/04/08 08:39 PM
08/04/08 08:39 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
thanks a lot guys
Re: trans cooler fitting size? [Re: 64dartsb] #98407
08/04/08 08:46 PM
08/04/08 08:46 PM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
What's the best thing to replace those with and where can I find it? I was just going to get a barbed fititng for the hoses I have on there now but I'd prefer hard lines of course. I have tubing benders what should I ask for if I want that. I can flare it with my brake line flare tool I think. Do you think the hardware store would have this stuff? should I just use brake lines for the trans cooler lines or is there something better like fuel lines?
Re: trans cooler fitting size? [Re: 64dartsb] #98408
08/04/08 08:53 PM
08/04/08 08:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Steel brake lines are best. You won't find any of that kind of stuff at a hardware store. Get everything from a auto parts store.
Re: trans cooler fitting size? [Re: Challenger 1] #98409
08/05/08 12:32 AM
08/05/08 12:32 AM
San Diego
64dartsb Offline OP
64dartsb  Offline OP
San Diego
cool thanks
-matt
Re: trans cooler fitting size? [Re: 64dartsb] #98410
08/05/08 02:16 AM
08/05/08 02:16 AM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
you can usually find the brass tube nuts you need specifically for the flare fittings on the tranny at a decent auto parts store too (Edelman brass fittings section usually behind the counter) so if you get the pre-flared brake line you can cut one end off and slide the nuts on then only need to take care of one end Saves you a little time at least
